  • Replies 18.9k
  • Created
  • Last Reply
Top Posters In This Topic
18 hours ago, e9stibi said:
Loren - I have a second spare CDR220 without code. Can you please provide?
Here are the details:
Becker CDR 220
type BE 6625
serial # 25011147
Thanks again in advance for for your help!
Becker CDR 220
type BE 6625
serial # 25011147
Try 4570
Hopefully someone is still active on this thread to help! Battery got replaced in my Carerra 4 and i have no manual or code from the previous owner.
CR-220
Becker 1
Type 4462
Serial # X5028023
Any and all help will be much appreciated!!
Hi I Like a zillion people replaced my battery and now by Radio Model # CR-210 is asking for a code.
Can someone please help me get the code so I can stop singing w/o a radio while driving? Desperate.
Radio: R-3297
Radio serial # W5020326
CR-220
Becker 1
Type 4462
Serial # X5028023
Try 2185
1 hour ago, Deborah Fifield said:
Becker 1 from 2000 porsche Boxster S
Ser # X50 35836
My manual says to use 2897 or 2899 - neither seems to work.
Try 2910
1 hour ago, Tim Burton said:
Hi Loren, Little help please for me 996?
1999 C2 Cab 996
CDR-220
Becker
Type 4462
Ser # x5016473
48/98
Thanks!!
Try 1070
51 minutes ago, 98 Boxster Guy said:
Loren,
I have a 98 Boxster
Radio: R-3297
Do you know the code?
sb
If 0530 did not work then chances are your radio has been repaired by someone other than Becker, In that case I can not help you. Sorry.
1 hour ago, 98 Boxster Guy said:
Once you put in the code it goes back to the first number and blinks. Is there anything else you're supposed to do?
No the radio should start after the last number of the code is entered.
So as I said...  If 0530 did not work then chances are your radio has been repaired by someone other than Becker, In that case I can not help you. Sorry.
I  recently purchased my first Porsche, a beautiful 1999 911 Carrera. Very little paperwork came with the car, and like a dummy I left the lights on overnight and my battery died. I do not have the unlock code. I have the following information...it is a Becker(I believe) CR-210 model# R3297. Serial # is W5(or possibly S) 011334.
any help I can get would be greatly appreciated.
Thank you,
Dwight
Thank you,
Dwight
Try 6819
