  • Replies 18.8k
  • Created
  • Last Reply
Top Posters In This Topic
  On 6/24/2007 at 8:38 PM, pennyporsche said:
Thanks so much. The first number worked.
Expand
Hi
I have just bought a 2001 911 Carrera 4 and I think the dealership changed the battery which resulted in the radio not working. Please assist with the code if possible.
CDR 220
type-4462
Ser-Y5052694
  On 8/6/2018 at 7:41 PM, Rallyerider 2 said:
Hi
CDR 220
type-4462
Ser-Y5052694
Expand
Try 8245
Hi, I need the code to unlock my radio from a porsche boxster S.
Radio is a CDR-220
Serial # 25013397
24/99
Cdp2081
Belker 1
type 4462
Is 2002 year
Edited by Rabiensa
  On 8/6/2018 at 9:00 PM, Loren said:
Try 8245
Expand
Thanks a million. It worked. But there was no sound. Took radio out and it seems that the previous owner seems to have cut the speaker wires off on the back of the radio and the ‘B’ plug is nowhere to be found. ‘A’ plug is in place.
  On 8/8/2018 at 5:43 AM, Antonio Nogueda said:
Hi. I have 04 cayenne 3.2 L I installed a new battery to sum and the radio it not working, howcan I get the code to turn on. My radio have navigation on it. I'll appreciate so much
Expand
You did not read the Lost Radio Code FAQ...
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
Your help would be greatly appreciate (after garage disconnected battery)
2000 Boxster
CDR 22
Type 4467
SN. Y5026515
Thanks in advance
I need a radio code, help! Wait message and my serial number is y5043037. “Type 4462”
hoping someone knows what they’re doing here because I definitely don’t haha
thanks!
Would love some help with my Radio Code please!
Model-no: BE 4720
Serial-no: X5010814
Thank you for your help!
Edited by MrRaw
