Good morning Gentlemen: I have just had major service, on my '01 986-S, including an unplanned new battery replacement (RMS, CV Boots, Clutch Kit), and have waited almost 1 month to get this thing back. I picked it up today 3k lighter in the wallet. (phewwww....). The CDR-220 of course is dead now, and I don't have the OEM Card - and so - with your grace, and help, perhaps we can get her rocking and a rolling again, (please):
Becker 1
type 4462
Serial No. 15002202
24/99
Many Thanks! wmweirich@hotmail.com :)
Santa Maria, CA 93455
  • Replies 18.9k
  • Created
  • Last Reply
Top Posters In This Topic
Becker 1
type 4462
Serial No. 15002202
24/99
Try 8404
or
8402
Becker 1
type 4462
Serial No. 15002202
24/99
Try 8404
or
8402
THANK YOU - this worked! Send me the invoice. :) On a serious note: THANK YOU!
Now - to try and install that Becker GPS - time permitting! (Traffic Pro) A little intimidating to say the least.
Thanks again!
Hello
Disconnected the battery for the winter and the code that was in the owners book did not work....
CDR 220
serial X5035126 :renntech:
thanks
Hello
CDR 220
thanks
Try 0562
or
0560
Thanks Loren for the reply
the code 0562 is what is listed in my code card however 0560 did not work I then thought maybe the serial number is different so i checked it and it says
99 boxster
Becker 1
4466
New Serial Number
x502 5213
So if you have time do you know the code for that one?
I really Appreciate your help!
Hi, I am looking for a radio code for my 1999.
Becker 1
CDR 220
Type 4462
24/99
Ser # 15075468
Thank You very much...
Larry C
Try 1218
or
1216
Hi Loren,
Both codes did not work.
1218 and 1216
Do you have any more suggestions?
Thanks allott,
Larry C
I'm going to be replacing a MAF Sensor on my 2000 Boxster 2.7 next weekend, and from other posts it appears that I might need to disconnect the battery and lose my radio code in the process. Please help me with the code if and when that happens.
The radio is a CDR-220 Becker 1 Type 4462 Serial # X5035823 24/99
Thanks a million for helping with this. I really appreciate it. - Jeff
Please let me know if you can help me with the code. I've decided that I will disconnect the battery when I replace the sensor and will need to reset the code. Thanks in advance! - Jeff
Sorry, guess I missed one...
Try 9211
or
9209
Try 9211
or
9209
Thanks - I'll let you know how it goes. I really appreciate it. - Jeff
I also replaced the ingition switch on my boxster, seems to be a common fault.
Now the ingition works fine but the radio is locked and I've lost the code card.
Radio: CDR-21
Ser. nr.: V5008384
Thank You so much.
Radio: CDR-21
Ser. nr.: V5008384
Thank You so much.
Try 3312
or
3310
Radio: CDR-21
Ser. nr.: V5008384
Thank You so much.
Try 3312
or
3310
Thank You, it worked!!
Arrgh ! Replaced my battery and can't find the radio code.
Becker1
Type:4462
Seri: Y5053043
24/99
Thanks !
Try 8957
or
8955
Thanks for the quick response yesterday ! I tried both codes and neither worked :-(. I did some more digging around and still couldn't find the card. I did find my second key which I'd looked for in the past ! :-)
Any suggestion for a next step ? Thanks again.
Becker1
Type:4462
Seri: Y5053043
24/99
Thanks !
Try 8957
or
8955
Lost Radio Code - FAQ, PLEASE READ THIS FIRST
Becker1
Type:4462
Seri: Y5053043
24/99
Thanks !
Try 8957
or
8955
Thanks Loren. I appreciate the help !
The radio code on the card that came with my car doesn't work. When I got the serial number from the display it didn't match the card.
Soooo... Can anyone suggest a code for SN Y5036705? Type = 4462. 2000 Boxster S
Try 0909
or
0907
