Hi
I just bought a 996 C2 with CR-21 and had to unplug the battery for door panel removal. I didn't realize the CR-21 would require a code afterwards, and unfortunately the previous owner never had to deal with that so no code.
Highly appreciated if Loren can help, this is what i got from the unit:
Becker
R 2097
V5007232
  • Replies 18.8k
  • Created
  • Last Reply
Top Posters In This Topic
Hi - I am the second owner of a 2002 Boxster S with a Becker radio. Can you help me find the code? Serial number is W5005742, type 4462. Thanks.
Never got radio code when bought 2001 boxster ,it finally happened lost battery power,need help to get 4 digit code .info Becker 1 type 4362,ser 15031011. Don't know what this means 24/99. Help me please.
  On 8/11/2013 at 9:45 AM, lphrg10 said:
Hi
Becker
R 2097
V5007232
Try 4614
Try 4979
Try 9083
Hi
Becker
R 2097
V5007232
Try 4614
Thank you. Excellent forum btw.
I have a 2000 Boxster --- Becker CDR-220 Ser # Y5040938. I am looking for the radio security code
I have a Becker Radio from my 2000 Boxster
Ser# Y5040938
Model: CDR-220
I just purchased this beauty and I would like the security code for future maintenance and battery loss.
Thank you...
Hello,
I have a 2002 Boxster S and just replaced my blinker switch and when I got it back from the garage
the radio code appeared. Obviously they disconnected the battery to when they replaced the switch. Really missing some tunes!!
type 4462
ser: 15009170
24/99
any help would be greatly appreciated!!!
  On 8/14/2013 at 3:29 AM, shakedown71 said:
Hello,I have a 2002 Boxster S and just replaced my blinker switch and when I got it back from the garagethe radio code appeared. Obviously they disconnected the battery to when they replaced the switch. Really missing some tunes!!type 4462ser: 1500917024/99any help would be greatly appreciated!!!
Try 9843
Hello. Saw the dates on this and not sure if it's still active? Just had a new AOS put in and now the radio wants a code. I bought it used and did not receive that info.
2000 Carrera 4 Cab
Becker 1
X5019881
Type 4362
47/98
Thank you in advance if you get this.
J
  On 8/15/2013 at 3:02 PM, jjmason.6 said:
Hello. Saw the dates on this and not sure if it's still active? Just had a new AOS put in and now the radio wants a code. I bought it used and did not receive that info.2000 Carrera 4 CabBecker 1X5019881Type 436247/98Thank you in advance if you get this.J
Try 9419
2000 911 4S 'Millenium'
Radio Serial #: P0801 0016 226 /02
I got Radio code 4275 from Dealer; after entering code, I press NEXT...and nothing happens.
Thanks for any suggestions
Try 4756
  On 8/16/2013 at 9:06 PM, jonh1 said:
Thanks for your quick reply. 4756 does not work either. Shall I go supplicate the Dealer?
What is the model name/number on the front of the radio please?
The radio head/screen has no number, just a top cassette slot labelled 'Porsche PCM'.
Unit in console below the dash but above the AC is a CD slot labelled 'Porsche Navigation' (which displays but does not navigate)
The screen requesting codes has two lines, the top labelled 'PCM' (which I assumed was for the radio) and the bottom 'Nav System'
This is why folks should read the Lost Radio Code FAQ -- FIRST.
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM's require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.Sorry, the only place you can get a PCM code is from a dealer/OPC."
