  • Replies 18.7k
  • Created
  • Last Reply
Top Posters In This Topic
  On 7/23/2013 at 12:49 AM, Loren said:
  On 7/22/2013 at 10:57 PM, GST said:
Hi. Need a code for my CR-220. s/n: W5002335
Try 7637
I'll try it this evening...thanks!
Hi folks!
Very excited to be a Porsche driver again! Just got a 2001 boxster s - couldn't resist as was a bargain with lots of work needed. Nearly there but there's no sign of the radio code so hoping there's someone around who can help.
Type 4467
Serial Y5036261
Becker 1
Cdr- 22
Many thanks.
  On 7/24/2013 at 12:20 PM, Sam32 said:
Hi folks!Very excited to be a Porsche driver again! Just got a 2001 boxster s - couldn't resist as was a bargain with lots of work needed. Nearly there but there's no sign of the radio code so hoping there's someone around who can help.Type 4467Serial Y5036261Becker 1Cdr- 22Many thanks.
Try 5036
  On 7/26/2013 at 12:42 AM, Mario Čajić said:
I hope I can get help.I have an '01 boxsterCR-220Becker 1Type: 4362Serial: 1505016224/99Please help! Thank you in advance!
Try 8464
Hello
I Need a code for my Becker from a 2000 911.
BE 2580
s/n 5033380
Thanks in advance
Stefan
Edited by stbo22
  On 7/30/2013 at 2:41 PM, colhi said:
Hi
I've lost the code for my CDR 220, the serial number is 25009805.
Could you help?
Thanks in advance
Try 5327
  On 7/30/2013 at 10:36 PM, r. gutierrez said:
Hi Loren,
Please send a radio code for me for a Type CDR220, Model BE4462, Serial #X5038227. Thank you.
Try 1304
All knowing Radio Code Oracle,
2000 Porshe Boxster
Cr-220
VIN WP0CA2981YU625235
SERIAL X50 10624
I tried using other online tools but I cannot get my Java settings right for it to work. My FOB no longer worked so I took the battery out to get it tested. I have searched this forum for some time on how to open the hood when FOB does not work. Fuse jumper did not work, could not find emergency pull. However, the screwdriver tricked worked. Now the levers do not lock, but that is fine by me. I do not need an alarm, but I do need access to the spare. Battery was fine :) So manual key it is.
2000 Porshe Boxster
Cr-220
SERIAL X50 10624
Try 5481
2000 Porshe Boxster
Cr-220
SERIAL X50 10624
Try 5481
There is no try, only do. Worked like a charm. A million thanks.
Brad
