Hello guys. I am planning to remove my cdr 22 because I want to connect AUX cable.
I don't have my Radio Code if something goes wrong. Can someone provide me a Unlock Code for:
Radio CDR 22
4467
Ser.: 15004504
Thanks!! P.S. I am really glad that I found this forum, a lot of interesting stuff! See ya around! :)
Try 5282
  • Replies 18.7k
  • Created
  • Last Reply
Top Posters In This Topic
Well same issue had to pull the battery for some work i was doing to the eng n door panels so i lost the code to stereo n guy i got it from has no clue.. thank you Ahead of time..Great site
2000 911/997
Ser# for radio Y5039988
CDP2081
4462
24/99 Manu Date
thanks!!!
2000 911/997
CDP2081
4462
24/99 Manu Date
thanks!!!
Try 7454
Wow Loren fast response.. THANKS..i still got "WAIT" showin on the screen but i will try that new codes in a lil bit...thank You!!!
Loren, hey i waited lil bit over an hour and its still displaying Wait?? am i missing something? thanks
From the Lost Radio Code FAQ... "You have to wait 1 hour - with the radio on and ignition switch on (or the car running)."
I am planning to replace my battery and cannot find the radio code. It is a 2004 996TT w/PCM, in preparation is there any way I can get the code from the radio/Nav system prior to removing the battery for replacement?
Thank you.
Randy
Thank you.
Randy
Please read the Lost Radio Code FAQ
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
Loren, Thank You soooo much you are Awsome... the first code you sent me worked!!!!! Now if i can get the nutty airbag lite off.... I had to remove airbag to replace window reg. so i unhooked batt. Anyway Thanks Again!!!
Airbag is another thread here.... please start a separate thread if you want to discuss that.
You will need Durametric software, a Porsche PST2, or Porsche PIWIS tester to turn off an airbag. That is assuming you have corrected the problem that turned it on.
Great, thanks Loren, worked! Really appreciate it :-)
--- michael
Good Day All! looking for a code for my Boxster radio:
Becker 1
4462
Y5044890
Thanks in advance! :-)
--- michael
Try 7106
I have a 1999 911 and need a radio code.
Radio is CR210
Model: R2095
Serial Number: W5010450
Thanks.
Hi Loren,
I am about to replace the steering lock assembly on my 2001 911 and do not have the radio code for my car. I followed the directions on this site and retrieved the serial number: 15076927 24/99.
can you please tell me the code as I do not wish to disconnect the battery until I have this information.
Mike Hatch hatchm@comcast.net
Hi Loren,
Try 7032
