  On 4/7/2012 at 6:52 PM, Loren said:
  On 4/7/2012 at 6:38 PM, Carreran said:
Hello!
I had my 996 4s disconnected from the battery over the winter period (sweden) so the radio requests a code now. Please help me.
My radio facts:
Becker1
4467
25010906
34/99
00
Thanks in advance!
Best regards
Carreran
Try 4659
Thanks it worked!
  • Replies 18.7k
  • Created
  • Last Reply
Top Posters In This Topic
New owner 2001 C4
No radio code. Radio is currently working, just want code in case I need it in the future.
type: 4462
s/n: 5050866
Thanks Loren.
  On 4/11/2012 at 8:06 PM, bobbunnell said:
New owner 2001 C4
type: 4462
s/n: 5050866
Thanks Loren.
Try 0765
HELP PLEASE RADIO CODE FOR 2006 CAYMAN S
TRYING TO INSTALL PARROT AND NOW ITS ASKING ME FOR THE RADIO CODE..
TNX!!
Edited by edus28
TNX!!
Please read the Lost Radio Code - FAQ -- 2003 and newer Porsches do not have radio codes.
The radio is matched with the car at the dealer/OPC using a Porsche PIWIS tester.
Hello,
I just bought a 99 Boxster but it did not come with the radio code. I will be having some work done to it and want to be prepared in case they wind up disabling the radio. My info:
CDR-220
Becker Model # 4462
S/N Y5048262
24/99
Thank you!
  On 4/18/2012 at 5:59 PM, lahightower said:
Hello,
CDR-220
Becker Model # 4462
S/N Y5048262
24/99
Thank you!
Try 5168
Hello Loren,
Lost radio codes for the pcm nav unit from my 01 911 turbo. Dealer gave me the codes for the pcm and nav but for some reason the unit will not accept it.
code the porsche dealership gave me for the pcm is 3209 and for the nav 1182.
The Becker serial # is Y5007409 and model # is be2582
There is also a Siemens serial # which is p08040064648/03
Is 3209 the correct code? Am I doing something wrong?
Any help would be greatly appreciated.
Thank you
  On 4/20/2012 at 6:55 AM, ericwma said:
Hello Loren,
Thank you
Please read the Lost Radio code FAQ
  On 4/23/2012 at 1:52 AM, Joseph Maduzia said:
Hello,
I just bought a used 1999 porsche boxster, and I unplgged the battery which, of course, reset the CD player.
CDR-220
Becker 1
Type 4462
SN X5032063
Thank You
Try 0124
  On 4/25/2012 at 4:44 PM, rabithouse said:
Yup, need radio code for my 2001 Boxster!
CDR 220
Becker 4462
Serial # 15085300
PLEASE DO NOT SEND ME A PM FOR RADIO CODES.
Try 9132
Hi there
Bought the car and did not get PIN code for radio. Here's the info:
Becker 1 CDR-22
Type 4467
Serial # Y5029801
24/99
Edited by JarmoL
  On 4/26/2012 at 6:32 PM, JarmoL said:
Hi there
Becker 1 CDR-22
Type 4467
Serial # Y5029801
24/99
Try 5195
  On 4/27/2012 at 8:13 PM, GarethThompson said:
Hi Loren,
Could you run the following radio code for me please?
CR220
4362
S # 1500 1858
Gareth
Try 0501
Hello,
i have lost mij code also but i cannot read mij sticker on mij trafic pro
this is what i can read
be 4276
x5016
can you help me
Hello,
I've got the power back on the car.
These are the numbers
BE 4721 (model number)
X501310 (serial number)
I hope you can find the code.
Thanks for so far.
  On 4/28/2012 at 7:10 AM, jaxob said:
Hello,
be 4276
x5016
can you help me
Hello,
Thanks for so far.
Try 56626
Thanks for the quick reply but the code is not working
hope jou have another the radio is a trafic pro
That is the code for a Becker Traffic Pro with the serial you gave me and 6 presets.
You could also try (for fewer presets):
51121
or
13222
If none of those work then the serial number you gave me is likely wrong.
Hello you are right
i have got the wrong ser
the right nubber is
be 4721
x5010310
i am so sorry hope this while help
thanks for al your help
hope to trij it soon have to wait you becouse i type the code 3 times
