  • Replies 18.7k
  • Created
  • Last Reply
Top Posters In This Topic
Hi All,
I have tried
1128
1130
6401
6403
& now the radio is counting down from 10 mins,does this means Ive run out of goes till the 10 mins relapses?
I think i got the code for the radio,but now it was the pcn that was left,this car has sat nav & it is 2001 boxster s,does this mean any different?
Hi All,
I thought i would add this info
Boxster S,2001,right hand drive,sat nav
Hi All,
I have tried
1128
1130
6401
6403
Hi All,
I already answered your other post on this - why are posting this here?
Sorry, the only place you can get a PCM (or Traffic Pro) code is from a dealer/OPC.
Hello! I have lost my radio code, someone can help me?
Becker1
type 4467
Serial: W5006481
Boxster 2.5 tiptronic,
year 1999
interior black
model Europe
Many thanks!
hello
My battery died over the winter
and cant find my radio code
maybe someone would be kind enough to help
becker cdr-220
type:4462
serie:x5033124
48/98
thanks in advance
dan
tried both of those to no avail...also tried 8620,21,22,23,24,25,26,27,28,29,30 continues to ask for code when putting in the numbers all 4 show up then first one start blinking
any other ideas?
1996 993 becker cr-210
r 2095
t5001718
Thanks in advance
any other ideas?
r 2095
t5001718
Thanks in advance
Please read the FAQ - that is all I can do.
Perhaps I needed to "Add a reply" instead of "Add a new topic?"
1999 996 Cab
Becker CR-210
Radio Model - R 3297
Serial Number - W5022363
THANK YOU, THANK YOU, THANK YOU
If this ended up in the right place (finally :-) That's probably where the confusion is. I was thinking that my "Start a new topic" would put my request in with the others. I'm new to this forum. Maybe right above the link in the FAQ, you could say "When you follow the link below, use the "Add Reply" button. Do not "Start a new topic".
1999 996 Cab
Becker CR-210
Try 6860
or
6858
If you have not already read this FAQ - please do so...
Lost Radio Code - FAQ, PLEASE READ THIS FIRST
Found this link - worked great. The first code it provided worked for me.
After entering the code, I had to press the UP button on the right side of the radio in my 1999 996. I was expecting it to just unlock after the 4th digit was entered. But it didn't unlock until I pressed the up button for "enter".
This website had the code I needed. (I think it only works for some models)
Radio Codes
