Hi Loren,
I do not have the radio code, but have not disconnected the battery yet. Is it possible to retrieve the radio code prior to powering it down?
If not, could you provide a code/s based on the following:
CDR220
Becker 1
Type 4462
Serial Y5039432
-Wayne
  • Replies 18.7k
  • Created
  • Last Reply
Top Posters In This Topic
  waynesworld said:
Hi Loren,
CDR220
Becker 1
Type 4462
Serial Y5039432
-Wayne
Sorry, the only place the code is besides on the card from the delivering dealer is possibly in the DME Vehicle Info page.
Only about 30% of the cars I have seen actually had that entry in their DME so I wouldn't count on it. Besides you need the Durametric Software, a PST2 or PIWIS to see that information.
Here are the best guesses for your radio code:
Try 3506
or
3504
Hi , I am going to install the ipod connection and will need to disconnect the radio. I do not have the code
it is a 2002 C2 Cab
3.6
the vin is WP0CA299X2S655135
Thanks !
Mike
it is a 2002 C2 Cab
3.6
Thanks !
Mike
Please re-read this thread for how to get your radio serial number (VIN has nothing to do with radio serial numbers).
I have a different problem: I have the card with the Serial# and Code# but the code does not work for some reason...
Type 4462
Serial W5008491
Code 8753
Maybe I can get it to work with a different code...can someone give me a hand this his issue?
Thank you
Type 4462
Serial W5008491
Code 8753
Thank you
Try 7752
or
7750
I tried both of those codes but they didn't work. Do you have any other suggestions? Thanks!
  Loren said:
  dmenn said:
Can you please help me with a radio code?
Becker
4362
25007445
24/99
Try 7070
or
7068
  Loren said:
Becker
4362
25007445
24/99
Try 7070
or
7068
Read the thread here.... there are other suggestions...
  Cheesy said:
Hello,
I need the radio unlock code for a 1991 964 Carrera
Model: CD-2
S/NO: PO CD-2 A 06 14719
Thanks.
I have no idea if this will work on the older radios like this.
But here goes...
Try 4985
or
4983
  Loren said:
  Cheesy said:
Hello,
Model: CD-2
Thanks.
But here goes...
Try 4985
or
4983
Sorry to ask, but how do you enter 9 and 8. The radio only has 1 through 6 with no second function that I can see.
Thanks.
Thank you Loren but unfortunately neither code 7752 or 7750 worked...any others that I can try?
Thanks again for your help.
  Loren said:
Type 4462
Serial W5008491
Code 8753
Thank you
Try 7752
or
7750
  Cheesy said:
  Loren said:
  Cheesy said:
Hello,
Model: CD-2
Thanks.
But here goes...
Try 4985
or
4983
Thanks.
Sorry, I don't know that radio well enough to tell you.
  Loren said:
Type 4462
Serial W5008491
Code 8753
Thank you
Try 7752
or
7750
Please Read - Read - Read -- I have covered this many times in previous posts here.
I hooked up my Durametric tool and the radio code wasn't in there.
Then I tried some different combinations close to the two numbers you provided.
7071 worked!! Thank you!
  Loren said:
  Loren said:
Becker
4362
25007445
24/99
Try 7070
or
7068
Well I just figured out Rennlist and Renntech are two different sites, no wonder I wasn't finding this topic.
I replaced my battery and lost the radio, when I bought the car five months ago, I did not receive any documentation nor radio cards.
My Radio is a Becker 1
Type 4462
SN# X5027630
Can someone tell me the codes to try?
Thanks for your help in advance
Randy
Type 4462
SN# X5027630
Randy
Try 9302
or
9300
  Loren said:
  Tufle said:
Lost my Radio Code on Boxter 2001 2.7l
with Becker Model 4362
Sn Y5023577
Thanks for the help. Much appreciated.
Tufle
Try 9134
or
9132
I was finally able to drive for an hour so I can type the code suggested but they don't seem to work, any other suggestions?
