  • Replies 18.8k
  • Created
  • Last Reply
Top Posters In This Topic
Hi Loren, Lost my radio code for my '99 Boxster.
Becker 1
CDR 220
Type: 4462
Serial # Y5061127
24/99
Thanks- Jackie
Try 4410
or
4408
Loren, thanks for getting back to me so quickly but the codes did not work. I even tried 4412,4411,4410,4409,4408,4407.
Anything else I can try?? Thanks again
If you have not already read this FAQ - please do so...
Lost Radio Code - FAQ, PLEASE READ THIS FIRST
Hi - New owner without the radio code and I need some work that will disconnect the battery.
1999 911 Cabriolet
Becker CDR 220
Model: 4462
Serial: X5017609
Date: 48/98
Your help is appreciated - Thanks!
CDR 220
Type: 4462
Serial: 15064891
24/99
Thanks in advance.
Try 7113 or 7111
Just back from my mechanic, and those codes did not work. I double-checked the serial number, etc. They also got a code from the dealer (2198) that didn't work either, and the one in the ECM (7168) also didn't work. Any ideas, or do I need to call Becker?
Edited by gnetwerker
CDR 220
Type: 4462
Serial: 15064891
24/99
Thanks in advance.
Try 7113 or 7111
If you used the method in the FAQ to display the actual serial number and my guesses did not work - then you will need to call (and pay) Becker.
Sorry.
HI
CD220
serial X50117888
model 43/62
Kare
Try 2935
or
2933
Sorry to bother, but didn´t work.
What should I try now, changing the last two digits? Now the radio tells me to wait...and there are quite many different combinations to try.
HI
CD220
serial X50117888
model 43/62
Kare
Try 2935
or
2933
Yes, just like the FAQ says you can try different combination or you can pay a dealer or Becker.
