Hello Loren,
I recently requested to code to my original Becker radio and it worked, but unfortunately spilled soda all over the radio due a sudden braking incident. I purchase a used CR-220 Serial W5007293. Can you please help with the radio code?
Thanks again.
  • Replies 18.7k
  • Created
  • Last Reply
Top Posters In This Topic
3 hours ago, quietcoolone said:
Hello Loren,
Thanks again.
Try 5102
36 minutes ago, quietcoolone said:
Thank you. Unfortunately that one did no work. Is there any other code to try?
If you gave me the correct serial number  - then no. Sorry.
That is the serial as displayed on radio unless the second digit is an "S" and not a "5"
WS007293. Could that be the case? Please check and advise.
Thanks in advance for the help.
Only the last four really matter.
