Hey Loren,
That worked! I really appreciate all of your help and your patients!
Thanks again my friend!
Edited by JCFX
  • Replies 18.8k
  • Created
  • Last Reply
Top Posters In This Topic
  On 5/16/2023 at 9:22 PM, Loren said:
Lost Radio Code FAQ
Expand
Hi
I have recently acquired a Boxster that has the PCM BE-2580. I know it says doesn't cover the PCM due to siemens doing the navi code, however I do have the navi code card and the code that came with the car. I literally require the PCM code only as was missing. Is this something that can be helped with please? If so what more is needed from me? Thanks in advance
  On 7/6/2023 at 9:21 AM, alanpettit said:
Hi
Expand
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM codes is from a dealer/OPC.
  • Like 1
I’ve been without radio for some time, hoping it is still possible to unlock. Thank you in advance!
Serial number pictured Y5047003 or YS047003
Siemens
5WK 78003 - - E
PO8030205471/04
996.642.904.04 EFR
SI000406010209
Becker
IDIS
BE 2580
55150096
Please I need 2 code for Porsche 996
  On 7/12/2023 at 3:20 PM, Tom ptr said:
Siemens
5WK 78003 - - E
PO8030205471/04
996.642.904.04 EFR
SI000406010209
Becker
IDIS
BE 2580
55150096
Expand
From the Lost Radio Code FAQ...
"These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM codes is from a dealer/OPC."
Hello, in need of the radio code for my Boxster, seems the card that came with the car is no longer with the owners manual.
Becker CRD-220
Ser: Y5041728
Type: 4462
Thanks so much!
Becker CRD-220
Ser: Y5041728
Type: 4462
Thanks so much!
Expand
Try 3292
Hello, We are hoping to get the radio code for this 2000 Boxster.
CR-220
Model: 4462
Serial: X5038003
Thank you!
