  • Replies 18.9k
  • Created
  • Last Reply
Top Posters In This Topic
  On 5/14/2020 at 1:29 PM, Lou Bev said:
Still struggling with this and I can't get the code. I called my local dealer 3 times and they never return my call. If you can help please.
It is a Becker 1
Type 4462
Serial# 25017566
Expand
Does it help you if I add the vin#?
Thanks Loren but neither one worked, but to be clear, I should only have to enter the correct code one time right? There is not a need to enter it twice for confirmation?
Also, not sure if it helps but here is the vin# WP0AA29902S623012
Expand
Yes, then wait a couple of minutes.
I gave you two possible codes because part of your last S/N LED is out - so we are guessing.
Hi Loren,
My battery died and now I'm stuck with no music.
02 911 turbo
CDR 220
Model Nr. BE 6625
Serial Nr. 25011906
VIN: WP0AB29992S686543
Thank you in advance!
