1 hour ago, MSTER9 said:
I have a few radios I bought used that didn't come with codes.
All are model CDR-220
Serial numbers:
Y5043042
Y5048852
15087358
Sorry, one per customer... unless you become a Contributing Member.
For Y5043042
Try 8951
  • Replies 18.8k
  • Created
  • Last Reply
Top Posters In This Topic
Hi Loren,
I am missing the code for my 996‘s radio:
Type: Becker CDR 22
Model: BE 4467
Serial: X5013149
Thank You so much!
Stephen
1 hour ago, SD996C2 said:
Hi Loren,
Type: Becker CDR 22
Model: BE 4467
Serial: X5013149
Thank You so much!
Stephen
Try 4206
  • Thanks 1
Hi Loren,
Sorry to bother you with this, but as I can see you are the person to ask, regarding radio codes.
When I purchased this car the previous owner never mentioned anything about the radio code.
It's only after I have replaced the battery last week that I have encountered this issue with the code.
I have a 986 Tiptronic.
The radio:
Type: CDR 220
Model No. BE 4462
Serial No. W5010344
12Volts EC:106
Part no. 996.645.126.00
I hope you can help me out, so looking forward to your reply,
Thanks in advance for your help on this.
Best regards, Barry
50 minutes ago, B. the Count said:
Hi Loren,
The radio:
Type: CDR 220
Model No. BE 4462
Serial No. W5010344
12Volts EC:106
Best regards, Barry
Try 0674
5 minutes ago, slidesideways said:
Hi Loren,
I am also missing the code for my 996‘s radio:
Type: Becker CDR 22
Model: BE 4462
Serial: Y5061024
Thank you, very much appreciated!
Try 0102
  • Thanks 1
For Y5043042
Try 8951
okay thank you I'll try that one
Hello Loren
I lost my code for my 2000 Porsche 911
CDR 220
type 4462
SN: I5088755
24/99
Any help would be greatly appreciated!
Larry in Greenville Sc
14 minutes ago, Saluda said:
Hello Loren
CDR 220
type 4462
SN: I5088755
24/99
Try 1543
For Y5043042
Try 8951
and it worked thanks again
Hello I as well have lost my code,
I have a Porsche 911 Carrera 1999
Becker 1 CDR-220
Ser : X5020829
Type : 4462
48/98
Thank you for your help!
Hello. I have a 1998 boxter 986. Had to disconnect battery to put in a new one but now radio is asking for a 4 digit code. When i bought the car the manual was not with it or any info on the radio. I was hoping I might be able to get the code. Radio is Becker CDR 210 ,type 3297, serial no. V5015026.
Thank you
Hi - I need help getting a code for my radio in my 1999 Boxster.  Its a CDR-220 and the serial number is X5023464.  Please let me know if you need any additional information.  Thanks in advance for your help.  Rick
Becker 1 CDR-220
Ser : X5020829
Type : 4462
48/98
Try 6874
Thank you
Try 5363
Try 4648
