  • Replies 18.8k
  • Created
  • Last Reply
Top Posters In This Topic
56 minutes ago, jjrebuilders said:
Hello everyone! Can you please help me out I need the code for the following radio:
Model #: BE 2162
Serial#: T5004145
Type: CR 210
Try 0904
15 minutes ago, porsche12 said:
Hey I've lost my radio code can i please get some help? Thank you
Becker
Type 4462
Ser # X5028133
Try 9243
Hey Loren thank you for the fast response, the code you gave me worked but the CD will not eject from the radio, I have another radio i got off ebay that i hope works, could you help me with the code? It's a
Becker
Type 4462
Ser# X5028881
48/98
Thank you again
Becker
Type 4462
Ser# X5028881
48/98
Thank you again
This is your third request - perhaps you should consider a donation -- so this site will be here when you need it.
Try 9609
98 boxster
s/n v5017004
becker cdr-210
please help I just purchase this car!
Edited by lorenz
23 minutes ago, Loren said:
Try 1323
thank you so much for the fast respond and the code did work! very appreciate it!
Model #: BE 4362
Serial#: X5017231
Type: CR 220
thank you
Model #: BE 4362
Serial#: X5017231
Type: CR 220
thank you
Try 1032
Hi everybody! I ve changed my battery and no longer radio et of course no code!!
BOXSTER S 2003
model: CDR 220
Serial: 15008701
Help me please!!
Nicolas
BOXSTER S 2003
model: CDR 220
Serial: 15008701
Help me please!!
Nicolas
Try 0187
Hi Porsche riders:
I recently bought a Boxster S 2002.
CR-220 Becker radio was not working, I complained and the seller handed to me a second Becker CR-220. Now I have two CR-220,  I will install one and will sell the other at an affordable price to a member in need of one. Please help me with the codes so I can put one to work at least (not sure which one will work), these are the Serial numbers:
UNIT 1
TYPE CCR-220
MOD BE6624
S/N 15004374
UNIT 2
TYPE CCR-220
MODE BE6624
S/N 15004263
Both units show CR-220 on front.
Thank you very much !!
54 minutes ago, GEORGE S said:
Hi Porsche riders:
UNIT 1
TYPE CCR-220
MOD BE6624
S/N 15004374
UNIT 2
TYPE CCR-220
MODE BE6624
S/N 15004263
Unit 1 try 7073
Unit 2 try 9016
Need code for 2001 Porsche 2001 Boxster.  Battery replaced and previous owner did not put the radio code on the manual
CDR - 220
Becker
Type-4462
SN - 15086209
24/99
:drive1:
CDR - 220
Becker
Type-4462
SN - 15086209
24/99
:drive1:
Try 4620
16 hours ago, Loren said:
Unit 1 try 7073
Unit 2 try 9016
Loren,
Thank you very much.
Unit 1 code worked fine.
Unit 2 Display panel doesn't work so I do not know if the code works or not, changed the fuse but it didn't help.. I will keep testing other solutions.
I am very pleased having an original device for this car's model working as new.
Best wishes to all.
GEORGE-S
