  • Replies 18.8k
  • Created
  • Last Reply
Top Posters In This Topic
Hi Loren, I hope you can help
I have a 2001 Boxster and the radio is locked up after a battery disconnect
Type 4462
Ser. 15 08 79 71
Type 4462
Ser. 15 08 79 71
Try 7184
Loren, you are a savior, that worked!!!
Thank you so much I have tunes again after a long absence. Thank you, thank you, thank you
Hi!
I restarted my 986 again after winter and noticed no battery...
Becker CR 220
Ser: X5027226
or Y5027226
(display a little bit defect... ;-) )
Thanks in advance!
Hi!
Becker CR 220
Ser: X5027226
or Y5027226
Thanks in advance!
Try 0982
Hello, may I get the code for my radio please.
Becker CR-210
Ser Code: V5017506
Thank you very much!
Try 2154
Sweeet it work thank you very much!
Hi Wonderful people,
I have a CDR 22 that I need an unlock code for plz:
___
Type: Becker CDR-22
Serial: Y5026966
type: 4467
___
Thank you very much. I think I will be be on here a fair bit!
Kind regards
Winno
Edited by Winno
___
Type: Becker CDR-22
Serial: Y5026966
type: 4467
___
Kind regards
Winno
Try 7434
Can you please send me the radio code for the following serial number?
SER: 15009627
MODEL:  Becker CDR-220
TYPE:  4462
Thank you very, very much!
Edited by macabrales
SER: 15009627
Model of the radio please?
