  • Replies 18.8k
  • Created
  • Last Reply
Top Posters In This Topic
diconnected battery on my 02 boxster radio cr220 the serial number is either 29005919 or 25005919 the second digit is not complete. appreciate your help
Try 7148
Try 7148
THANK you that was it
HI there Loren, I hoping you can help me find my radio code
I have a Porsche Boxster 986 1997
Serial N. VS600894
CR-210
by the way the screen says "WAIT", I guess it is because I tried too many times and failed.
Serial N. VS600894
CR-210
Try 0979
HI there Loren I just tried it 0979 and it didn't work, you know if there is something wrong with it. Because I followed the instruction you gave.
Serial N. VS600894
CR-210
Try 0979
Oh sorry I did another comment, just to let you know that it didn't worked, the 0979 code
Serial N. VS600894
CR-210
Try 0979
Did you follow the procedure to get your serial number in the Lost Radio Code FAQ?
Please do so and re-submit.
Serial N. VS600894
CR-210
Try 0979
Serial N. VS600894
CR-210
Try 0979
Hi Loren the
SN: T5002155
I will thank you a lot for you help for the code
Thank you
