I recently bought a '99 996 Cab with a faulty battery, replaced it and shazam - a locked radio.   Owners manual was for a different car and the code card was not included.
Becker CR-220 Type 4462   Serial #X5020122
Greatly appreciate help on this.
That worked - thank you so much.
  • Replies 18.8k
  • Created
  • Last Reply
Top Posters In This Topic
Have 99 996. Same problem here are the serial numbers of the radio:
Radio SN X5008323 Becker
Siemens PO8010013065/02
Porsche 996.642.105.02 FER
5wk7801
Can you help? Need the pcs code
5wk7801
From the Lost Radio Code FAQ...
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
I am swapping out the Kenwood installed by a prior owner with the OEM Becker CDR-220 and don't have the code.
From the side of the Becker unit:
Model #   BE 4462
Serial #   15086917
Manufacture Date   22/01
Thank you!
Just got a 2000 Boxter.
Radio is not working due to missing code, of course.
Please help me get the code for it.
Model Becker: Type 4462
Serial: X5037035 (not sure if the "X" is part of the code)
Please help
post-103265-0-78032600-1440521401_thumb.
Edited by svldvc
Please help
Try 1471
Model #   BE 4462
Serial #   15086917
Thank you!
Would love a code next time you're here Loren!  Thx…
Model #   BE 4462
Serial #   15086917
Thank you!
Try 6942
Model #   BE 4462
Serial #   15086917
Thank you!
Try 6942
Thanks for your help!!!
Please help
Try 1471
Thank you soooo much!!!
It worked!!!
I freaking LOVE tight communities as this one!!
A million thanks!
