  On 5/6/2011 at 8:58 PM, leosmith78 said:
I have a CR-220, when I held down the TP button for 10 seconds and 'scrolled' through the options, Becker 1 came up as Loren said, but when I scrolled to the serial number portion it just said, 'seri'. It's a 4362. It also said '24/99' and a reset option...please help...how do I find the ser number?
Try the procedure again. If that fails then you will likely need to pull the radio out to read the serial number tag.
  • Replies 18.8k
  • Created
  • Last Reply
Top Posters In This Topic
Thanks Loren...I tried a few times and the serial number is a no-go. I even put a little pressure on the face plate and tried because sometimes I don't get a good "seat"...still no joy.
I did, however, find a manual, written by the previous owner, "code: 4678". I tried to enter this 3 times and locked the unit out...now I'm waiting for it to unlock again. It didn't say it was for the radio, but I'm not sure what else it could've been for.
I'm physically unable to pull the unit out of the dash myself due an injury, but if I can't resolve via other means, I may have to resort to the local Stealer.
So, my questions are, should I try maybe incrementing the last two digits of the above number as I've seen in other posts?
Are there any other things to try when the radio doesn't take the code, assuming that 4678 is the correct code?
Thanks for all your help, I really appreciate it!
Last resort. Try taking the faceplate off and cleaning the contacts with electrical contact cleaner or an eraser. Then try again.
Ok, Loren...I found the code...the REAL code. I actually found the radio code card and the code was totally different than the one I posted earlier...see what happens when I assume? Anyway, radio is working...thanks for your help.
  On 5/8/2011 at 1:00 AM, guitarninja said:
Just got the 1998 boxster out of winter storage... I have the CR-210 with serial W5010428
Thank you so much in advance!
Try 4930
  On 5/7/2011 at 11:04 PM, Loren said:
  On 5/7/2011 at 10:44 PM, mpm17 said:
I'd love to have a radio code.
CDR-220
Becker 1
Type 4462
x5024745
48/98
Try 8787
Worked like a charm. Much appreciated.
  On 5/8/2011 at 1:02 AM, Loren said:
  On 5/7/2011 at 11:10 PM, Kelevra84 said:
Hi!
Becker Cdr 220
becker1
4467
x5020684
thx!
Try 8545
thank u so much, loren
Hello, I have an 02 996 with the stock Navigation / radio unit. I changed the battery today and don't have the radio code. How do I get my serial # so i can get the radio code?
Please help! Much appreciated .
thanks,
Ben
thanks,
Ben
PLEASE READ THE FAQ.
Lost Radio code FAQ
I think I have the PCM system... does that mean it won't work for me?
thanks,
Ben
Lost Radio code FAQ
thanks,
Ben
Lost Radio code FAQ
A radio would like this
and PCM looks like this
  On 5/9/2011 at 6:05 PM, like to drive said:
Hello,
Need help with a 2001 Boxster S. Battery died and can't get the radio working.
Becker 1
CR 220
Type 4362
Ser 15030823
Thank you!
Try 6826
Hello,
Becker 1
CR 220
Type 4362
Ser 15030823
Thank you!
Try 6826
That worked! Thank you so much!
