  • Replies 18.8k
  • Created
  • Last Reply
Top Posters In This Topic
Hi
I have a 1999 boxster . I replaced the battery and now I need the radio code that I don't have.
Radio specs :
Becker CDR 220
type BE 4462
serial # 15062353
Thanks for your help :)
Try 6780
or
6778
I tried all those numbers : 6774,6776,6778, 6780,6782,6784,6786,6788
none of them worked, should I try more number ? or do you have any other number I can try ?
Hi
Radio specs :
Becker CDR 220
type BE 4462
serial # 15062353
Try 6780
or
6778
PLEASE read the FAQ.
hi everyone, any help is appreciated. thanks!
porsche cdr23
be 6612
serial 25027730
date 49/02
Please read the FAQ - CDR-23 does not have a code. It must be matched with the car using a PST2 or PIWIS tester.
Hi Loren,
the preowner of my 996 Cabrio lost the code card.
It would be very nice, if you can help me out.
2002 996 Cabrio 3.6
Porsche CR 220 (Becker)
Type 4362
SER. 25006797
Thank you very much.
Best regards,
Christian
Hope you can help - I tried my girlfriend's front panel from her Landrover (Becker BE4765) to see if it works, but now my Porsche radio needs it's code and I was never supplied with it when I bought the car second-hand!
Hope someone can help with the code for this:
CR 22
BE 4367
Serial X5015563
Also, if anyone knows where to get the code for a BE4765 (serial 75030541) then I'd be grateful
CR 22
BE 4367
Serial X5015563
Try 5562
or
5560
Hi Loren, this is a fine resource you have. Any chance you can supply a code for my 2.5? -
CDR22
Becker 1
Type 4467
Serial X5016240
Thanks in advance,
Hi Loren,
I tried 8817 and 8819 back in Oct.
CR 210; Model 2182; SN W5012002.
Nothing worked from 8807 to 8829.
Are there other codes that may work or is it off to the dealer for me?
Hi Loren,
Hi there! I am in need of a code for my radio in my 2000 Carrera 4. Here is the info:
CDR-220
Becker1
4462
Serial #2501543
24/99
Roch. :D
Trying to get my stereo working...
Porsche 996 C4S -02
CDR220
Y5060521
Try 0073
or
0071
Did´nt work... Its so weird since someone did write "radio code 5278" in the Porsche Maintenance book but that one did´nt seem to work either...
Well, I´ll guess I have to take it to the dealership.
Thank you so much for your help though!!
I have just purchased a 2000 Boxster (base). The battery was disconnected for transport. The radio (Becker 1) serial number is X5018515. Any numbers to try.
Thanks for the assistance.
