  • Replies 18.8k
  • Created
  • Last Reply
Top Posters In This Topic
Hi Guys.....Need code for radio....Thanks Paul. Becker 1 Type 4462 Serial # Y5043547 24/99 cd cdp2081
Bought it about a year ago......no radio code card. :rolleyes: 2000 BoxsterS
Hi Loren, I lost my code:
2001 996 C2 Gray outside and inside
LHD
Shingle Springs, CA purchased Niello Rocklin
Becker CDR 220
Model BE 4462
SN Y5061362
Scott
Edited by sheatley
New 3rd owner of a beautiful 95' 993 with a radio upgrade that didn't include code card.
I could really use the code to turn my radio back on after fixing the infamous horn beeps rapidly by itself while braking hard problem. :)
Becker Porsche CDR-220
Model BE 4462
Serial number off radio barcode 4462DH015085093
Serial No Field From Sticker : 15085093
Nick
Model BE 4462
Nick
Try 9481
or
9479
Have a 911 carrera 2; 1999.
Supplied radio code doesn't work for some reason. Details are:
CDR32
4667
X5005299
02/99
SCD CDP2081
Appreciate any help!
Hi Loren:
I tried 0626 and 0624 as suggested. Also 0625. All with no luck.
Scott
LHD
Becker CDR 220
Model BE 4462
SN Y5061362
Scott
Try 0626
or
0624
Did you read the FAQ for other suggestions?
Model BE 4462
Nick
Try 9481
or
9479
Thanks so much. Neither code worked but I remembered a suggestion from the FAQ and tried 9483 and it worked great.
Thanks again.
Nick
I lost my security code for the CDR 210 that is in my car. Since I replaced the battery, it asks for the code. Can you please provide a security code?
The Model # is BE 2282
The Serial # is V5007105
Thanks in advance for any help you can provide.
L. Herrera
L. Herrera
Try 9197
or
9195
L. Herrera
Try 9197
or
9195
Thanks Loren! Read the FAQ. Very helpful. Thanks again.
Please help with radio codes. 2000 Boxster S.
Believe its a CDR 220
Ser: X5035776
Type: 4462
CD: CDP2081
Much appreciated if someone can help.
Have Boxster 2000 S, need code for:
Becker
4462
48/98
X 5025946
thanks for info in FAQ - turns out I was given the wrong serial # info from the prior owner. The TP button confirmed the # given was wrong.
Thanks for your help!
