Hi, I hope someone can help. I just had my car painted and they disconnected the battery and now I have lost the radio code. this is the info I have found. I'm not sure how to go about getting it. Any help would be appreciated.
Becker 1
type 4462
# Y5038582
24/99
  • Upvote 3
  • Replies 18.8k
  • Created
  • Last Reply
Top Posters In This Topic
Try 5650
or
5648
Hello,
I have the same problem, I wasn't aware of the unlock codes for the radio when I changed the battery.
Becker CDR 220
type BE 4462
serial # X5023044
Thanks for your help :)
Try 5650
or
5648
Hello,
Becker CDR 220
type BE 4462
serial # X5023044
Try 8967
or
8965
Try 5650
or
5648
Hello,
Becker CDR 220
type BE 4462
serial # X5023044
Try 8967
or
8965
Thank you so much, I 'll try it the next week :)
If those don't work and you have access to a DME reader, I believe it's listed under Vehicle Data
- Old Blevins
Sometimes it is listed in the DME Vehicle Data - but frankly not very often.
Of the half dozen or so times I've looked to see if the factory or dealer put it in - only twice has it been there.
I have a 2000 Boxster S with the radio locked up due to a dead battery. Called the Porsche dealer but he will not give out the code without taking the car in.
BE4462
Y5041794
Jim
BE4462
Y5041794
Jim
Try 6401
or
6403
BE4462
Y5041794
Jim
Try 6401
or
6403
Thanks for the quick reply! I'll try these as soon as I get a chance.
Jim
BE4462
Y5041794
Jim
Try 6401
or
6403
Jim
Neither of those codes worked, but 6404 did, so I'm back in business! Thanks a lot. I appreciate the help.
Jim
Same problem. Disconnected battery for front end work.
Becker Automotive Systems
Type: CDR 220
Model: BE4462
Serial: W5005114
Code we have does not seem to work?!! Please help!
Thanks - Seth
Yet another second owner with no Radio Code!! Any help would be most appreciated!!
2000 S
CDR-220
Becker
Type 4462
Ser # Y5039229
24/99
Thanks!!
2000 S
CDR-220
Becker
Type 4462
Ser # Y5039229
24/99
Thanks!!
Try 11128
or
1130
IMHO it would be really useful if some of you guys could reply with which code Loren suggests actually works. It might help make more accurate predictions. Just my 2 cents worth.
  • Like 1
Hi guys! Really need help here....
I bought a replacement CDR24 radio from Ebay & after installing into my 2007 Cayman, it shows 'PORSCHE' follow by 'PROTECT'.
Is there anyway to get it to work???
Radio model : 6645
Serial No. : 65046091
Axxession No. : 0431786
Security code : 9287 or 9265
Hope the experts here can help!
Wilson
