  • Replies 18.7k
  • Created
  • Last Reply
Top Posters In This Topic
Hello,
I have a 2000 C4 and need the radio code. The code that came on the radio card does not work -0473
BE 4362
X 5020571
Please help. Thanks.
Try 0473
or
0471
Second owner, need to change battery...
2001 Boxster S, 6 sp manual, black interior, US
Radio:
Becker 1
Type: 4462
SN: Y5061228
Thanks in advance.
Firstly, let me say Loren you should get a medal for all the help you give here..
Yet another radio code request due to change of battery:
2000 Boxster
Radio: Becker CDR-22
Type: 4467
SER: Y5026133
Please help!
Radio:
Becker 1
Type: 4462
SN: Y5061228
Thanks in advance.
Try 2386
or
2384
2000 Boxster
Type: 4467
SER: Y5026133
Please help!
Try 9611
or
9609
My battery died and the radio code card in the car doesn't work. The previous owner said the radio had been replaced.
TYPE 4462
SN 25012942
24/99
Try 0981
or
0979
Thanks for trying, but codes didnt work for me...
Waiting for a call from a delaership so hope they can help
Found lots of sites offering codes for 3-10 quid - will these work or are they likely to give me the same codes that dont work?
TYPE 4462
SN 25012942
24/99
Try 0981
or
0979
0983 worked. Thanks!
Hi All. Beautiful sunny day in SF, need to go on an hour drive down south. Hoping to get the radio code to listen to instead of headphones! :=)
Thanks a million for your help. Beers on me if you are ever in San Francisco.
Type 4462
Serial 25010889
One more question, it is currently in a wait state. I understand I have to wait 60 min, any way to sidestep that or make it go by faster?
Type 4462
Serial 25010889
Try 0937
or
0935
Help,
I need a radio code.
becker 4462
Y5051412
Thanks for any help,
John
Try 4610
or
4608
Both did not work, any other idea?
Thanks for your time,
John
Help,
becker 4462
Y5051412
John
Try 4610
or
4608
John
Didn't read the FAQ - did you?
Please read this and follow the instructions...
Lost Radio Code - FAQ, PLEASE READ THIS FIRST
Sorry, I did not read all of it before.
I'll try the other codes.
Thanks for your time.
John
hello have a radio code problem
becker
ver-3297
serial-w5022669
thanks
Try 4461
or
4459
did not work any others? oh and I have another problem, the radio only works when key is in the acc position. It never works when car is running, this started about 2 yrs ago when it would turn off when driving. the fuse is good what other things should i check?
becker
ver-3297
serial-w5022669
thanks
Try 4461
or
4459
Didn't read the whole FAQ - did you?
If you are having other strange electrical problems - that relate to the ignition switch position. Then you very likely have a bad ignition switch also.
