1 hour ago, Drybones said:
5651 didn’t work unfortunately
From the Lost Radio Code FAQ...
"The suggested number did not work - what do I do now?
Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work."
  • Replies 18.7k
  • Created
  • Last Reply
Top Posters In This Topic
Hey Loren thank you in advance!
2002 911
cdr-220
becker 1
type 4462 or 4452
serial 25013184 or 25018184
my screen has dead pixels hence possible two numbers I’m pretty sure it’s the first sets 4462 and serial 25013184
Thank you so much!
2002 911
cdr-220
becker 1
type 4462 or 4452
Thank you so much!
Try 5486
Ah thanks, I’ll start calling around to some dealers and see if someone wants to help. Thanks for checking!
Hello, this would be a life saver:
99 C2
CDR210
R 3297
W5019519
I found a 4 digit code written on some paperwork, unlabeled of course, 7522, but it doesnt work.
Edited by gerglmuff
99 C2
CDR210
R 3297
W5019519
Try 8787
Hey Loran, first again many thanks for radio code help for Boxsters (you've helped me with three different 986s).
Do you have the decoder ring for 993 Becker radios as well?
Model#:  BE2182 (stamped on radio body), R3297 (from display lookup),
Serial#:  V5008819 (from the display lookup)
Edited by AustinPorscheBill
adding radio information
Try 6529
1 hour ago, AustinPorscheBill said:
Worked, thanks Loren.
Got two radios with the car, now that I know you can go back that far, here's the second:
Model# BE2282
Serial# V5007553
Try 5104
Hey Loren
Could you help my with a radio code?  I disconnected the battery while working on the car and now I cant find the code anywhere.
CDR-220
Type 4462
Serial 15065035
Thanks I appreciate the help!
