  • Replies 18.7k
  • Created
  • Last Reply
Top Posters In This Topic
Hi, my Boxster just came in with a dead battery and the radio needs the code. Can anyone help me please?
Becker
Type: CDR-220
Model - No : 4462
Serial - No : X5037704
Thank you for the help!
Becker
Type: CDR-220
Model - No : 4462
Try 0721
  • Thanks 1
Hi Loren,
Are you able to help fine the code for my CDR -21 Serial is W5017748, I’m not sure of the model number.
If you could help that would be great
thanks so much
11 hours ago, Riley_ said:
Hi Loren,
thanks so much
Try 4647
I repurchased a '97 Base that I sold a few years ago. No manual came back with it, though.
A CDR-221 Ser#5007697 Model BE2282? The code was in the manual
Thank you!
Jack5j
Hi Loren,
I need your help again please! last unit crapped out - got a replacement but no code with it.
Model :CDR 23 / BE 6611
Serial : 25012749.
Thanks again!
1 hour ago, Jack5j said:
Thank you!
Jack5j
Try 0765
  • Like 1
33 minutes ago, Jeeplife said:
Hi Loren,
Serial : 25012749.
Thanks again!
From the Lost Radio Code FAQ...
"CDR-23 (or later):
These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected."
  • Like 1
Hi Loren:
Your help would be greatly apprecaited.  I have a 2000 Boxster S with model 4462 and serial number X5037854.  Third owner, disconnected the battery and didn't even think about radio security...
Again, thanks,
Dave
7 hours ago, Lombo1439 said:
Hi Loren:
Again, thanks,
Dave
Try 9079
20 minutes ago, Tintin14 said:
Hi, I need help retrieving a code for Becker CR22 BE4367 Y5022055, any suggestions would be greatly appreciated
Try 1060
  • Thanks 1
Hello,
I've got the same old story. My radio:
- CR-220
- Model: 4367
- Serial: X5018812
Any help would be much appreciated! 🙂
1 hour ago, villet said:
Hello,
- CR-220
- Model: 4367
- Serial: X5018812
Try 5473
