2 hours ago, WaWaW21 said:
Hi, just hoping I could get some help with my radio code
Type - CRD-22
model - BE 6621
Serial - 15002210
Thank You!
Try 8468
  • Replies 18.7k
  • Created
  • Last Reply
Top Posters In This Topic
Would greatly appreciate radio code for...
CD-2200
Serial Y5014064
Type 4466
24/99
Many Thanks, Ron
CD-2200
Serial Y5014064
Type 4466
24/99
Many Thanks, Ron
Try 8937
  • Thanks 1
57 minutes ago, m491drew said:
Didn’t seem to work - started flashing the first digit again after entering
Is that the serial number as displayed on the unit or the serial tag on the top or back?
The serial tag may not be correct if the unit has ever been repaired - even by Becker.
If a third party ever repaired they didn't reset serial number properly - if that is the case I can't help you.
On 7/6/2023 at 4:08 PM, Loren said:
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM codes is from a dealer/OPC.
Hi Loren,
Unfortunately the codes from Porsche dont work and it turns out that the serial number of my unit is different to what was originally supplied in the car. They say no way of helping. Any suggestions? I have the nav code and just need the pcm code (have serial no etc).
Hello, new 996 owner and the CDR220 needs a code, looked everywhere and the previous owner doesn't know where it went.  Any assistance would be greatly appreciated, thank you
Model 4462
Serial X5033503
48/98
Tom
Model 4462
Serial X5033503
48/98
Tom
Try 4960
  • Like 1
