1 hour ago, Ray Victor Cabuslay said:
Hi Loren,
Please help with my radio code. No radio card in the manual. Thanks so much.
Ray
Type: CR220
Model: BE4462
Serial: Y5054208
Try 5092
  • Replies 18.7k
  • Created
  • Last Reply
Top Posters In This Topic
Loren,
My apologies.  I believe you sent the right code, but it isn't accepting it. Any ideas?
Sorry to be a bother.
Best,
Michael
1 hour ago, MichaelOK said:
Loren,
Best,
Michael
What do you mean not accepting it?
Dear Loren,
I understand you can help recover radio codes. What a nice service. I just bought a 2000 Boxster with a CDR-220 with no code. The serial number is
X50227629. Thank you.
42 minutes ago, Jake Swanson said:
Dear Loren,
Try 9296
We have confirmed that the code you sent is correct, but it isn't being accepted by the radio - acting exactly as if it is the incorrect code.
Then the radio may have been repaired by a 3rd party (not Becker). I think only Becker can fix that.
That makes perfect sense.
Michael
I have a CDR23 in my 2003 911 Cab.  I plan on replacing the radio.  My question is - can the CDR23 be put in a non-Porsche and work?  I have a MGTD that I would like to use the radio in.  Thanks.
Not likely going to work - IMHO.
CDR-23 (or later):
These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
On 10/20/2020 at 7:46 PM, Steven Harper said:
Need help with a radio code for a Boxster I just purchased. Its a CDR-220, type 4462, with serial number Y5045162.  Really appreciate it!
Try 0850
29 minutes ago, Patrick Lopes said:
I have a 2002 Boxster, radio is locked, CDR 220 Model BE 6625 S/N 15005843, would you be able to help me with the radio code?
Try 2956
