  • Replies 18.7k
  • Created
  • Last Reply
Top Posters In This Topic
Just now, Per Bäckström said:
Hi I have an Boxster from 2003 with a Becker radio CR-2200, serial number 2500 1200, see picture. Do you have a code to unlock it? BR Per Västervik Sweden
Try 8578
  • Like 1
Hi and thanks for all of the help here!
I have a CR-220 radio in a 2001 Boxster S.
Serial # is 15050293
Type # is 4362.
Do you have a code to unlock it? Thank you!
Type # is 4362.
Try 7681
Hi I have a 2001 Boxter looking for the radio code
CR-220
Type 4462
Serial Y5054179
Edited by mdferndog
I just bought a 2002 Boxster and the seller had replaced the battery, but didn’t have the code documentation. I did the procedure found in the FAQ and could use a hand finding my unlock code for this:
type 4462
24/99
#1506 1867
Hi everyone,
Serial is W5002390 on my CDR-220 Type 4462
Is it possible to get the code?
Edited by Fabrice
type 4462
24/99
#1506 1867
Try 0573
  • Like 1
14 minutes ago, Fabrice said:
Hi everyone,
Try 0762
5 minutes ago, Loren said:
Try 0762
That's the code i have in the booklet but doesn't seem to work. Any other possible issue?
Did you use the procedure in the Lost Radio Code FAQ?
If not, then please do so and repost with the correct serial number.
Yes i got it through the TP button. I will try again in 1 hour when the WAIT resets... I'll go see the dealer if it doesn't work
I tried again after the WAIT period, definetly gave the good Serial and radio won't take the code. I am not finding anything online regarding this issue. Anybody have any clue? Or should i go to the dealer?
Chances are that your radio was repaired at some time by someone other than Becker. So, sorry no know will be able to fix the radio other than Becker.
Ok thanks, i will try to pull out the radio or see if i can find another code from a repairman. Otherwise, i'll just buy a new one.
It is a sad day for me today.
Thanks a lot for your help
Hello all,
I installed a new battery and do not have the radio code.  Any help?
boxster 02
CDR220
CDP2081
type 4462
Serial # 25016476
Anthony
1 hour ago, Anthony C said:
Hello all,
boxster 02
CDR220
CDP2081
type 4462
Serial # 25016476
Anthony
Try 1094
  • Thanks 1
Hi -
New user, putting in bluetooth/aux module on Becker CDR-220.  The car came with all the records since new, but the radio card wasn't present.
Please share code for:
Type:4462
Serial #: Y5035237
24/99
Thanks in advance,
Eric G
