Could you please check for my radio code.
model #4462
serial #5012669
Try 4461
or
4459
Neither of those worked. But I forgot the X in font of 5012669 so my serial is X5012669 if that makes a difference.
Edited by mastermind3d
  • Replies 18.7k
  • Created
  • Last Reply
Top Posters In This Topic
Loren,
Need help with a security code for:
Becker CR210
Model#BE2182
Serial# V5008187.
Thanks.
Mike_E
Try 9663
or
9661
Loren,
Neither code worked, went above and below by 15, no luck. Later got code from car-audio-accessories.co.uk, advised code 9765 which did work.
Hope this feedback helps you to understand the code process better.
Finally, many thanks for taking your time to help me out.
Best Regards,
Mike_E
model #4462
serial #5012669
Try 4461
or
4459
No the X does not make any difference.
Please read this and follow the instructions...
Lost Radio Code - FAQ, PLEASE READ THIS FIRST
Loren,
Can you help me? I replaced the battery on my Boxster but can't find my code..
CDR 220
TYPE: 4462
SER# X5036248
24/99
Thank you in advance..
model #4462
serial #5012669
Try 4461
or
4459
Loren,
CDR 220
TYPE: 4462
SER# X5036248
24/99
Try 4932
or
4930
Hi, Loren:
We bought the car used without the radio code. Then the turn signal return broke. I won't disconnect the battery to do this repair until I get the code. Can you help?
CDR-210
Type R3297
Ser # V5016395
Alan
Hi, Loren:
CDR-210
Type R3297
Ser # V5016395
Alan
Try 3276
or
3274
model #4462
serial #5012669
Try 4461
or
4459
Loren,
CDR 220
TYPE: 4462
SER# X5036248
24/99
Try 4932
or
4930
Awsome!! it works!! Loren, Thanks!!! :renntech:
Hi, I hope someone can help. I just had my car painted and they disconnected the battery and now I have lost the radio code. this is the info I have found. I'm not sure how to go about getting it. Any help would be appreciated.
Becker 1
type 4462
# Y5038582
24/99
Hi, Loren:
CDR-210
Type R3297
Ser # V5016395
Alan
Try 3276
or
3274
Loren:
I tried these numbers and the the numbers on both sides of them. Am I out of luck and on my way to the dealer?
Alan
Hi, Loren:
CDR-210
Type R3297
Ser # V5016395
Alan
Try 3276
or
3274
Loren:
Alan
Help please for CDR220
Becker
4462
Y5046607
24/99
Try 9308
or
9306
Thanks Loren,
Neither of the codes worked - unless I have to push additional buttons befoe/after entering the code. Any suggestions?
Thanks again!
