2000 2.7l
CDR-220
Becker
Type 4462
Ser # X503 2865
48/98
Bought car used - no radio card... Thanks in advance!
Try 6781
or
6779
I just noticed I mis-typed the serial #... should have been X503 1865. Must be Monday moring...
Try 0555
or
0553
  • Replies 18.7k
  • Created
  • Last Reply
Top Posters In This Topic
need Lost code for 2000 boxsters
cr-220 radio
S/n # x5019939
47/98
4362
Try 3467
or
3465
Those did not work do I press anything after the #?
It was one number higher not two as the faq suggested. Thanks
Hello,
I plan on doing an ipod aux mod to my cdr-220. Can you please help me with the code for my unit before I render it unusable?
Type: 4462
Serial: 25013498
24/99
Hello,
Type: 4462
Serial: 25013498
24/99
Try 5918
or
4916
Hi there - was messing with radio and disconnected it (looking to possibly replace with another unit), without realising the code card wasn't with the rest of the owners manuals - DOH!
Boxster S, 2002, RHD RoW, 6 speed, Seal Grey, Black leather interior (full option)
Becker
Type CCR22
Model No: BE 6620
Serial No.: 15001280
Hope you can help before wife finds out she has no sounds now in the car!!!!
Cheers.
Becker
Type CCR22
Model No: BE 6620
Cheers.
Try 6386
or
6384
hey loren just bought my car and radio doesnt work. can you help me please
cr 220
becker 1
serial y5023805
type 4362
thanks alot pat
Try 2527
or
2525
cr 220
becker 1
serial y5023805
type 4362
thanks alot pat
Try 2527
or
2525
hey loren i tryed thouse codes and they didnt work. can you try again for me, i also tryed 2523 2529
thanks alot,
pat
Loren,
Just bought a radio off ebay & I need a code:
CDR 220
serial x5031216
type 4462
Thanks in advance!
Hi Loren,
Just bought a '00 Boxster S with PCM/Navi on auction, however no codes (car was repo'ed and I got it dirt cheap)
Read your advice that PCM codes can only be obtained via the dealer, so I called the local chaps and they kindly looked up the codes based on the VIN, but to no avail, as these codes do not unlock the unit.
Dealer is at a loss. Do you by any chance know if there is a solution to this?
Love your site, this is my first Porsche and I already learned a lot from browsing around in the forums.
Cheers,
Henrik
Hi Loren,
Cheers,
Henrik
Did you get the PCM serial number off some paperwork or directly off the PCM?
Sometimes a unit gets swapped out under warranty and the dealer forgets to give the owner the new card with the serial number and code.
Best thing to do is to remove the PCM and check the serial number on the unit.
Hi Loren,
Just got some work done on my boxster and need a code.
CDR220
Becker1
Type: 4462
Ser: Y5048897
24/99
Thanks in advance
Ryan
Hi Loren,
CDR220
Becker1
Type: 4462
Ser: Y5048897
24/99
Thanks in advance
Ryan
Try 3321
or
3319
Loren,
CDR 220
serial x5031216
type 4462
Thanks in advance!
Try 2290
or
2288
OK I tried these 2 codes & I tried 2292 & 2286 to no avail....
Any other codes I should try ?
Also any way to get around the 1 hour wait period?
Should I just call Becker? Or wont they help?
Thanks again for the great resource!
:renntech:
Loren,
CDR 220
serial x5031216
type 4462
Thanks in advance!
Try 2290
or
2288
:renntech:
You need to read this...
Lost Radio Code - FAQ, PLEASE READ THIS FIRST
Loren,
CDR 220
serial x5031216
type 4462
Thanks in advance!
Try 2290
or
2288
:renntech:
I did, kind sir. So you are saying that I'm in the 5% ?
Or should I continue to search #s in the 2 digit ranges? How far either side of your suggested # should I go?
Loren,
CDR 220
serial x5031216
type 4462
Thanks in advance!
Try 2290
or
2288
:renntech:
Yes, if the two numbers I gave you don't work then you can try 2 digit increments/decrements until you get tired and call a dealer - or get lucky.
I recently had to replace the battery on my 1997 Boxster. I contacted my local dealer regarding assistance with resetting the code for the radio and was informed that I would need to make an appointment to leave the vehicle with the service department for such a problem. I learned of your kindness in assisting many others with this same issue and wondered if you would be able to help me. I followed your instructions as to retrieving the model and serial numbers. It is a Becker CR-210, Model # R2896, Serial # T5002027.
Any assistance that you can provide would be greatly appreciated.
Try 9019
or
9017
Hi Loren,
Cheers,
Henrik
Spot on, that did the trick - much obliged /Henrik
Try 9019
or
9017
I was unsuccessful with the code attempts but very much appreciate your effort. I am glad to have found this forum and hope to one day contribute information.
Thank you for your time.
Very truly,
Ashley Nichols
Montgomery, Alabama
Sorry Loren I cant seem to get it if this is wrong I will not bother you again, my apologies.
2001 Carrera C2 radio CR220
Becker 1
type 4362
ser number X5019877
47/98
