Hi, I hope you might be able to help me out with a code. Here's my info:
CDR-220
Becker 1
4462
X5016898
48/98
Thank you,
A~
Try 3205
or
3203
  • Replies 18.7k
  • Created
  • Last Reply
Top Posters In This Topic
CDR-220
Becker 1
4462
X5016898
48/98
Thank you,
A~
Try 3205
or
3203
Neither worked but I appreciate your help!
Hi there,
Need your help... I have a 98 Boxster that had a dead battery. After changing it the radio is asking for a code. The following is my info:
CDR-210
Ser#: V5017335
Thanks in advance!
Jesse ;)
Try 9022
or
9020
Hi Loren,
Thanks for the codes above. Unfortunately these did not work. I tried 9022, 9020, 9018, 9024, & 9023. Any other suggestion would be greatly appreciated. Many Thanks!!
Hi there,
CDR-210
Ser#: V5017335
Thanks in advance!
Jesse ;)
Try 9022
or
9020
Hi Loren,
Lost Radio Code - FAQ, PLEASE READ THIS FIRST
Hi there,
CDR-210
Ser#: V5017335
Thanks in advance!
Jesse ;)
Try 9022
or
9020
Hi Loren,
I had already read the FAQ and understand the rules... I was just hoping you'd have a diff code based on what I've seen in some of the previous requests. If not, no worries - I thank you for your time and patience.
need Lost code for 2000 boxsters
cr-220 radio
S/n # x5019939
47/98
4362
Try 3467
or
3465
Those did not work do I press anything after the #?
cr-220 radio
S/n # x5019939
47/98
4362
Try 3467
or
3465
You don't press anything except the four code numbers at the "Code" prompt.
:oops:
1128
Hi Loren,
Do you happen to know how to get the code for a becker cdR220. It's s/n is 15009805. It's in my 2002 boxster s.
Ryan
:oops:
1128
Hi Loren,
Ryan
Try 5227
or
5225
Same problem battery was disconnected and now we need the radio code,
Here is the info,
cdr 220
serial number: x5028668
Try 9920
or
9918
:oops:
1128
Hi Loren,
Ryan
Try 5227
or
5225
I tried both of those plus 5226 but no luck. Any other thoughts?
Thanks much for the quick response...
Ryan
Just brought home my 1999 Boxster, but no radio :(
CDR 210
R 3297
W5023240
Thanks in advance!
Try 8518
or
8516
The 8518 code worked. Once I figured out the key to press to accept the code, everything was fine.
Edited by tennvol
2000 2.7l
CDR-220
Becker
Type 4462
Ser # X503 2865
48/98
Bought car used - no radio card... Thanks in advance!
Try 6781
or
6779
I just noticed I mis-typed the serial #... should have been X503 1865. Must be Monday moring...
