Try 2470 or 2468
I tried the codes and it locked me out with the "WAIT". So now do I have to wait for an hour before trying a few variants? Or is there another way to enter multiple codes without being locked out? Like try one, then turn the car off and remove the keys before trying a second variant? Anything like that?
Did you read the FAQ?
You have to wait 1 hour - with the radio on and ignition switch on (or the car running).
Yes Sir, I did read the FAQ. I was asking if there is a way to try multiple codes while AVOIDING the 1 hour lockout. I think I found it!
3 false tries locks me out for 1 hour. So here's what I do:
1. Try two different codes, then remove my keys and wait for the unit to power off
2. Re-insert my key, and the unit says "WAIT".
3. Wait 5 minutes, with the key in the ignition
4. Code entry screen returns!
5. Repeat step 1.
So I kept trying 2 new codes every 5 minutes (better than waiting 1 hour between every 3 tries). I tried: 2466, 2468, 2469, 2470, 2472, 3468, 3470, 1468, 1470.
The magic number was 2471! So it was 1 number away from the suggestion (rather than 2, as stated in the FAQ). I posted my "retry" process here in hopes that it will help others, and contribute to this great community! Feel free to add it to the FAQ if you see fit. It greatly speeds up the trial & error process =)
i promised $10. PM an email address to send it to, or I would be happy to contribute it to this forum. Your call. THANK YOU, again!
Edited by MetaChimp
  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
Hi
We just discovered (after changing the battery) that the code card that was included with the car is not for the radio that is now in the car. Maybe the original was stolen or broken??
Here is the information that we have found and we hope that you can help us.
B & A
Model CDR220
Type 4462
Ser Y5033962
Try 0951
or
0949
Lorne
Wanted to write and thank you for saving the day. We tried the 2 codes you supplied and neither worked. I remembered that you suggested going up or down by 2s. I thought up and my wife thought down, so of course we went with hers. She was right (****). Anyway the radio works and you save the day.
Bob & Annette Lendrum
Good day, yet another lost code card.
My car is a 2001 Boxster vin WP0CA29821U626836
Radio type 4362
S/N 15050051
24/99
Thanks in advance for your asistance
P2001
Radio type 4362
S/N 15050051
24/99
P2001
Try 0408
or
0406
Recently purchased a 2001 Porsche Boxster with Radio CDR220
VIN: WP0CA29831U625257
Serial: WS011980
Type: 4462
Called Porsche dealer and was given Code 6864 but didn't work.
Do you have an alternative code?
Edited by stinky_onion
Serial: WS011980
Type: 4462
Try 5059
or
5057
Hi my wife left the headlights on and i end up with locked up radio to which i don't have the code.
After hrs of calling and digging around the web i found your site.
Quote "Help me Obi-Wan your my only.... "
Becker CDR-220
model no 4467
serial x501897
vin WP0ZZZ98ZWS605081
Thanks in advance.
Becker CDR-220
model no 4467
serial x501897
Thanks in advance.
Try 0811
or
0809
Becker CR-210
PR-VERS 3297
Serial WS023721
Try 9271
or
9269
So far Ive gone from 9269 to 9273 and have not had any success. Should I just keep trying from 9260-9280?
The lockout has been slowing me down.
Sorry Loren,
Posted request on wrong board. :( No code#
I'll be quick.
Model CR-220
Model 4362
S/N X5017008
( 47/98 )
Thanks !
Try 1253
or
1251
Hi Loren
i recently bought a PCM M680 radio
I can't activate it without the codes
Here is the info on the radio itself; there are two labels on this box. THe radio box is big and composed of two units that are put together and held together by the Navigation Screen. SO they are NOT independent of each other. I tried contacting Becter Automotice Services and they said the entire unit is made my Siemens; yet the box has a label on it that says Becker. Go-Figure!
Siemnes
Porsche 996.642.105.04 EFR
MFLFB: 5WK 78004
Serial No.: P08040106348/03
Date: 00120803 SW5.25
Becker
Type: IDIS
Model No.: BE 2582
Serial No.: Y5007946
KW: 40/00 65 31 35.20.40
Hi Loren
Siemnes
MFLFB: 5WK 78004
Becker
Type: IDIS
Model No.: BE 2582
Sorry, only a dealer can give you codes for a NAV system.
Loren, I'm kind of new to BLOGS, Posts, etc. but I was told you could help me get a radio code for my 2002 Boxster. I had the battery replaced yesterday and I don't know the Radio code. The unit is a Becker 1, Type 4162, Serial # 15007323. Thank you for any help you can give me.......
Try 8926
or
8924
Sorry Loren,
I'll be quick.
Model CR-220
Model 4362
S/N X5017008
( 47/98 )
Thanks !
Try 1253
or
1251
No joy on those codes, Do you any other alternatives ??? Thanks.
Knickknack
Try 8926
or
8924
8926 was the winner. Thank you again
Request for lost radio code:
2001 Carrera 911
Becker 1
CDR-220
Type 4462
Serial: Y5044860
24/99
Thanks in advance for your help.
2001 Carrera 911
Becker 1
CDR-220
Type 4462
Serial: Y5044860
24/99
Try 3281
or
3279
2001 Carrera 911
Becker 1
CDR-220
Type 4462
Serial: Y5044860
24/99
Try 3281
or
3279
Neither worked....now in "Wait" mode...
Try 2470 or 2468
5. Repeat step 1.
Thank you very much ! Your tip worked for me... F.Y.I. On my radio the ( Wait ) legend disappeared
after approx. 1 min.
