1 minute ago, Dr90210 said:
Yes, I did .
The bar code means nothing to the radio code - did you use the procedure in the Lost Radio code FAQ to get the serial number to display on the screen?
  • Replies 18.7k
  • Created
  • Last Reply
Top Posters In This Topic
Ok.
I used THE PROCEDURE.
Hi Loren would you please help me retrieve my radio code on my boxster 2.7 2002
vin no WPOZZZ98Z29603811
MODEL CDR 22
TYPE 4467
No 25008625
thanks in advance Kezz
MODEL CDR 22
TYPE 4467
No 25008625
Try 6094
37 minutes ago, porsche146 said:
Hi - Please can you help with a code for my CR-22 Radio:
Type: CR22
Model No: 4367
Serial: 15040923
Thank you
Try 4795
Sorry, didn´t work .
I don´t know what to do ??
It would appear that someone repaired the radio improperly.
Contact Becker Autosound.
Hi, just another guy with no radio code here.
CDR-220
Becker
4462
s/n X5032437
Thanks to everyone at this wonderful site.
CDR-220
Becker
4462
s/n X5032437
Try 4632
ok . thank you very much .
Hi, I've lost my radio code on my CDR220 can someone please help me?  My serial # is X5030860.
Cheers,
Mark
12 minutes ago, Rich jones said:
Hi hope you can help, I'm new to this Porsche stuff and when I changed the battery and lost radio code.
Type BE2580
sn 15060075
thanks
rich
You did not read the Lost Radio Code FAQ...
" Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/ OPC. "
Hi Loren, please help.....bought this great 90 911....original becker radio in car (CR-220) everything worked but no tuner, just static. I take to a radio installer, he "guarantees" me that it's the radio, so he changes it and guess what....it was the antenna instead. so I have him put back my original radio and of course now I need a code....here is my radio info:
Becker 1
Type 4462
Serial # 25011028 24/99
GAL 00
problem #2....so it's my antenna or booster I'm guessing. the installer said it's a nightmare to take dash off and try to fix and wanted to add an aftermarket, sort of stick on dash type antenna. I was not comfortable with this...so I ask you or any other Porsche owner that had a similar situation what they encountered and possible solutions.
Have a great day and thanks in advance!
R.S.
Becker 1
Type 4462
GAL 00
R.S.
Try 1034
30 minutes ago, SuncoastBoxster said:
1999 Boxster... Had to disconnect the battery due to ignition switch - Radio is CDR-210 with Serial Number W5023261.  Thank you!
Try 8686
