I followed the Lost Radio Code FAQ procedure and my Becker CDR220 info is:
Type 4462 / Serial number 5024524
Many thanks in advance... !
Try 6542
  • Replies 18.7k
  • Created
  • Last Reply
Top Posters In This Topic
Try 6542
Perfect... I've written it down in 3 places... ! Thanks for the help, and quick too... !
Hi Loren,
I appreciate if you could help out with the following:
CDR-210
R 2595
SN 1004042
Sorry can't find my post from yesterday
V5007153
r 2896
CD-R 210
Code 9393 won't work
This is a different serial number than you posted yesterday.
For this serial number try 9583
Loren I must be going crazy the first SN /code worked 9393 worked not sure, but I am certain I saw the other SN. Apologies in the extra work! Stereo is on! Thank you
If you could help with my CDR-210 Code I would appreciate it.
The serial number is BE2282V5010088
I have tried 4298, 4288, and 4286 and none work.
Charlie
Charlie
4298 is the correct code for that serial number.
Did you use the Lost Radio Code FAQ procedure to get your serial number?
If not, please do so.
If you did then sorry I can not help you.
