Rats! That didn't work either.. wonder if I'm entering it incorrectly.  After the "wait' goes away and the stars show up with the numbers I enter the code... should I be pressing another key?
Please read the Lost Radio Code FAQ - make sure you use that to get your serial number.
All instructions are there.
  • Replies 18.7k
  • Created
  • Last Reply
Top Posters In This Topic
Hello,
I have the same problem, I wasn't aware of the unlock codes for the radio when I changed the battery.
Becker
Typ: IDIS
Model No.: BE 2580
Serial No.: 15077488
Thanks for your help :)
Hello,
Becker
Typ: IDIS
Model No.: BE 2580
Please read the Lost Radio Code FAQ.
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
Greetings All,,
i'd be grateful for any help in unlocking the radio in my car.
1999 Carrera 4
Porsche (Becker) CDR-22
Serial Number X5011588
I twisted the seller to fit a fresh Bosch battery to it when I purchased it last week and then found the radio not to be operable on the drive home.
Many thanks in advance.
Chris
Try 0419
Spot on !
Thanks Loren.
CR-220
model: BE 6624
Serial number# 15003427
If I can please get the code, that would be awesome!
Edited by 911F1
Hello,
Can someone help me with my radio code. Dead battery, installed new one and radio does not work.  :help:
CR-220
Type 4462
Serial Number X5026345
48/98
Thank you,
Joe (Sugar Land, Tx)
Edited by jalcala
Hello Loren
I'm in the same boat, battery died and now I'm locked out.
It's a CR-220
Model 4362
Serial 15031723 24/99
Any help would be much appreciated.
Thanks in advance.
Hello Loren
It's a CR-220
Model 4362
Thanks in advance.
Try 8767
Hello Loren
It's a CR-220
Model 4362
Thanks in advance.
Try 8767
Great, worked without a hitch, thank you very much...
hope someone can help, disconnected battery to try and resolve another issue with drivers window and thought i had a stereo that did not require a code but alas that was not the case
type 4467
serial 15000193
24/99
Any help would be greatly appreciated!
Joe
Edited by youngjob
Hello and I am looking for some assistance.  I also had the battery in my 2000 Porsche Boxster S disconnected for a new alternator.  Now it's asking me for the stereo code.  It's the Becker 1, type 4462, serial # X5033083.  Thank you!
Edited by boxster1reno
type 4467
serial 15000193
24/99
Joe
Try 3297
Try 1094
type 4467
serial 15000193
24/99
Joe
Try 3297
My hero thanks Loren!
Ims bearing replacement completed but of course now asking for a radio code. I have a cdr220 with serial number Y5048324 in a 2001 boxster S
Try 9248
Hi Loren,
996 Carrera, 1999 US Version       BE 2582, Serial Nr.: Y5007973
3 x Porsche Stuttgart sent me a wrong code !
1x Porsche Salzburg - wrong code
Are they confused ?
Please Loren, need help ! Every time put in the wrong code I had to wait for 1 h.
Thank you  - Peter from Salzburg/Austria
