  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
Hi. I sent my 2004 Boxster S Anniv Edition to the shop for some paint. When I got it back the computer and clock were reset. I assume the battery must have died. The stereo does not power on when I hit the power button. Stays dark. Is this a case of needing the code, or is there probably more to it?
This is a CDR23.  Where would I find the serial number, if that is needed?
Please read the Lost Radio Code FAQ
"CDR-23 (or later):
These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected."
"CDR-23 (or later):
Thank you, Loren.  Google led me straight to the forum, missing the FAQ.  Fuses are good, so hopefully it's just the fuse on the back of the radio, if I can figure out how to get *that* out.  Again, thanks for the info.
Hey I have a '99 996 C4 which recently had the alternator replaced and now I need the radio code..
It's a CDR-22
Serial: X5016902
Other info:
CDP2081
4467
Any chance you could help me out? Thanks in advance.
It's a CDR-22
Serial: X5016902
Other info:
CDP2081
4467
Try 3238
Loren, you absolute legend! Thankyou so much, it worked like a charm. No longer must I be subjected to my own thoughts!
You really have all my gratitude - you've helped a hell of a lot of people on here!
Hi, i had to replace my battery for my porsche and now my radio is asking me for a code. My radio is a cr-220 the type is 4462 and the serial number is x5013524. Thank in advance
Try 8712
Try 8712
Omg thank you so much! I've been without a radio for months. Thank you thank you thank you!!!
Wow, this is amazing. Thanks for helping us out.
I have a CDR220 that came out of a 996, Model 4462, Serial x5021783. The code I was given doesn't work, any help would be greatly appreciated. Thanks in advance!
Try 2732
Hello,
I have a 1999 a with a Becker CR-210, PRVERS - R3297, SN W5023172 and need the code.
Thank You,
B-rad
Try 2732
Worked perfectly. Thank you so much.
Hey guys im new here and I just bought a brand new 1999 boxster! Awsome car. Car has a porsche navigation/cd unit. Type PCM : BE 2562 Serial# x5008026
searched all over for code in the trunk and on a card. Nothing. I would greatly appreciate if you can generate me a code! thank you
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
