Yet another car missing the radio code. I am going to unhook the battery to install the original steering wheel/airbag and do not have the radio code. Also, I would like to know if there is a way to verify that the code is correct without having the radio locked. Radio is:
Becker 1
type: 4462
Serial number: 15005578
Boxster S 2002
  • Replies 19k
  • Created
  • Last Reply
Top Posters In This Topic
I hope someone can help with my code. I replaced my battery and now the radio is asking for a code. Here's my info:
CDR-220
BECKER 1
TYPE 4462
SER: Y5036852
24/99
Thanks very much in advance. :D
Try 2835
or 2837
Thanks for the quick response but neither number worked. Am I doing something wrong or are there other numbers I can try?
Thanks so much for the help. :)
My program does not always work. It works maybe 95% of the time but I have no expanation why it doesn't always work.
At this point you will need to contact a dealer or Becker. Becker charges to lookup your code and some dealers do too.
Loren, 2838 worked. Thanks for leading me in the right direction. You saved me a trip to dealer and $$. Thanks again.
Help. I need a radio code for a CDR-210 in a 1999 996 I just bought. It is showing CODE with the "C" flashing.
I think the S/N is W5018297
And what is the procedure to enter it? I see the buttons below correspond to the digits I enter, but is there a button I press/hold afterwards to confirm entry? My car does not have an owners manual (I plan to buy one).
Thanks for any help.
Here is the link to download the manual for the CDR-210: http://www.renntech.org/forums/index.php?a...mp;showfile=543
I can't give you a code, but hopefully Loren will see your message and help you out.
Good Luck!
Try 5446
or
5448
Try 5446
or
5448
Try 5446
or
5448
Neither code worked. I entered the code and then pressed the signal seek switch each time.
I got the S/N br pressing the 8 and 0 at the same time and selecting S/N - is that the best way or should I pull the unit and look at it? Thanks.
Sometime the program does not work and in that case you will need to contact a dealer or Becker.
I do not know about a CDR-210 but on CDR-220 you don't press any keys after the code.
Thanks for the try. I do appreciate it!
You guys have been great helping out others with their lost radio codes. Think you might be able to do one more?
2001 Boxster S
Becker 22o
serial Y5023592
Type 4362
Please?
Hi, I hope someone can help. I just had my car painted and they disconnected the battery and now I have lost the radio code. this is the info I have found. I'm not sure how to go about getting it. Any help would be appreciated.
Becker 1
type 4462
# Y5038582
24/99
Hi Penny.
How did you get the information about type and number that you posted? I have no paper work on my CR-210. Also, when you entered the codes that were suggested to you, what procedure did you use? Just replace CODE with the four digit number? And then the first number kept blinking. What did you do?
Thanks for passing along the information you already got.
Nancy
Hi i bought my car from auction and it has no radio code :(
BE 6625
Serial # 15005923
Thanks so much its killing me not having any tunes!
BE 6625
Serial # 15005923
Try 7177
or
7179
Same issue. 2002 Boxster. Replaced battery and do not have radio code. Any help would be appreciated
Terry
Becker 4462
serial number Y5035192.
Hi loren
I had a misfire fault code on no 5, so replaced all the coils as some had cracks in . done a reset on the DME as per some article on another website to clear the CEL more than 20 sec but less than 50 and you wont lose the radio code, well guess what, i lost the radio code any chance of some of your magic please
It has a cdr-22 radio. my vin is ys604059 model no 986 311 anything else you need to find it out
many thanks in advance
Russ
UK
Hi loren
Russ
UK
Is that your VIN or radio serial number?
If it is your radio serial number then try 8893
or
8895
Hi loren
Russ
UK
or
8895
Hi Loren
Many thanks for your prompt response. Thats my vin number ys604059 where would i find the serial number for the radio
Russ
How to get your radio to display the serial number has been covered here many times. As well you can download the manual here.
Please do a search...
Learn something new everyday switch on hold down TP for 10 seconds. would'nt have found it without this forum many thanks.Could'nt find how to do it in the radio manual that came with the car.
Becker 1
type 4467
Serial no Y5026921
24/99
Becker 1
type 4467
Serial no Y5026921
24/99
Try 6971
or
6973
