I do not know if my program works on CDR-32.
Do you know if your security code is normally 4 digit?
Yeah it's a 4 digit code for the MDR-32.
Why O why couldn't i have just had a normal CD player rather than a MiniDISC!
  • Replies 18.7k
  • Created
  • Last Reply
Top Posters In This Topic
If the 2 codes Loren gives for your becker radio doesn't work, head to http://www.beckerautosound.com/ and click "request code" button. Fill out the form and send in to becker with $30 on credit card, and you'll have your code and new code card. MUCH cheaper than going through the porsche dealer and no proof of ownership required.
My experiance with this: I filled out the form and used the email option. i also edited the form in bold letters at the top asking for the price on a set of keys to my radio incase i needed to pull it out again. i got an email back with in 24 hours stating my radio code for instant use and that they were mailing the keys along with my code card free of charge!! received both of those in about 2 days. good luck everyone.
Loren,
Do you have the code for a Becker radio model # BE6104, serial # 15003026?
Thanks for your help.
Gary Knox
Try 8821
or
8819
Thank You Loren, I'll give those a try.
Gary Knox
Hi, just bought a 2000 plate Boxster S, need radio code, Trader I bought it from can't help.
Becker: 4367
Serial: X5019496
49/98
Hoping someone can help me
Hi Loren,
Spring battery change on my 99 Boxster and no radio code, your help would be appreciated.
Per your directions radio info is:
Type 4462
Serial Number X5018984
Thank you for your time.
Mike
Hi Loren,
Type 4462
Mike
Try 7601
or
7599
Hi Loren,
Type 4462
Mike
Try 7601
or
7599
Thank you, will give those a try. Need to "wait", which is a good reason to go for another drive today.
Thanks again. 7602 was the code, wrote it in the owners manual for the next time / owner.
Edited by mikeinsky
Neither code worked nor did 2 above or 2 below. I appreciate your help, and I will contact Becker as your post suggests.
Edited by jecbotb
Loren,
Update: Becker sent me the code - it was 6947, just 1 above the code that you provided me. Thought that you may want to know for intel.
Thanks.
thanks loren. sorry
i have a CR220
Type: 4362
Ser # 15003585
anything else?
Try 0015
or
0013
Loren- These two codes are not working.....Am i doing something wrong. I input the 0015 and it goes back to the code reset....
OK. Now I'm in the right place. Sorry about the other thread.
I lost my radio code when I changed the battery. Please Help.
Typ: CDR220
Mod: BE4462
SN: X5016959
These numbers are on both the loose sticker found in the bottom of the case, and from the read-out on the display.
?? Once the code is recovered, can it be brought up in the display in the future before disconnecting the power? Or do I need to resort to writing it down on the MFR sticker under the front hatch ----?
Thank You.
Brian.
Typ: CDR220
Mod: BE4462
SN: X5016959
Thank You.
Brian.
Try 7277
or
7275
The number does not display in the radio (ever) - so you will need to write it down somewhere.
Loren,
I removed the battery for the winter, and upon replacing it I realized we never got the code when we bought the car second hand.
My info is as follows:
2002 Boxster
Type: CDR220-Cassette
Mod: BE4362
SN: 15003935
24/99
These numbers are from the read-out on the radio display.
Any help you can provide would be greatly appreciated.
Loren,
2002 Boxster
Mod: BE4362
SN: 15003935
24/99
Try 0735
or
0733
Loren,
2002 Boxster
Mod: BE4362
SN: 15003935
24/99
Try 0735
or
0733
Those two didn't work, but 0737 did!
Thank you so much for taking the time to help - what a great forum.
My local dealer wanted to charge me an hour labor to get the code.
