  • Replies 18.7k
  • Created
  • Last Reply
Top Posters In This Topic
Try 9025
Hi Loren,
I tried the radio code 9025 on my radio ser#x5036831 and I could not get the radio code to work. Would you have any other suggestions?
Try 9085
Hello guys. I drive a Porsche Carrera 4S, 2002. I have a PCM and lost my code. Is it possible to restore?
If I understand from this post below, correctly PCM codes cannot be restored?
http://www.renntech....radio-code-faq/
The silence is killing me! :) Please help!
Thank you!
Edited by vytas
Thank you!
Per the FAQ...
Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC.
I just replaced my battery and have lost my code.
I have a CDR-220, type 4462, SN: 15085430
Can you help me out with the code please? Thanks!
ja996tt
2001 996 T
ja996tt
2001 996 T
Try 7431
HI i have a CDR 220
type BE4462
W5006516
EC 103
996.645.126.00
thats what the radio label says help me get an unlock code plaese
Did you read the FAQ? Why did you PM me 1 minute after you posted this?
Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in this one thread.
Try 1414
Hi - first time posting. Great info here! Looking for a radio code please:
CR220
Model #: 4362
SN: 25007195
Thanks in advance.
Dirk
CR220
Model #: 4362
SN: 25007195
Thanks in advance.
Dirk
Try 0734
This worked! Thank you so much Loren!
Just purchased a Boxster and radio stated wait. Need code for serial number Y5043004 it's a CDR 220
Truly appreciate any help, thx.dug
Hi, got a CR220, SN Y5023445. Has a replacement sticker on it, so the original code card does no good. Can you help? Thanks! -Jon
Try 0912
Thanks Loren!
Hello Loren,
I changed the battery of my Porsche and don't have the code, could you please help me? Thanks a lot.
Becker CDR220
model: BE 4462
Serial #: Y5060163
Thanks a lot!
Hello Loren,
Becker CDR220
model: BE 4462
Serial #: Y5060163
Thanks a lot!
Try 8472
Hello Loren,
Can you please help me get the radio code for me 996 Porsche C4
Becker CR220
model: 4362
Serial #: X5013016
Thank you
Thank you Loren, It worked great. Thanks for the prompt response and support
