yes i got it off of the (hold TP button for 10 seconds) method... there is only numbers, no letters
Sorry, I think you are going to need to call a dealer or Becker. Last time I checked Becker charged $30.
  • Replies 18.7k
  • Created
  • Last Reply
Top Posters In This Topic
Ok, just a small correction,
CDR220
4462
15008570
(was able to put the new battery in without disconnecting everything by using the battery charger trick someone else mentioned, thou still need a code to do the rear speaker upgrade).
Try 1968
or
1966
1970 worked!
Thank you
Hi, I have a 1997 RHD (UK) Boxster and need a radio code if possible please.
CDR-21 (210 in US?)
R1996
V5009848
Many, many thanks if you can assist.
Try 5571
or
5569
CDR-21 (210 in US?)
R1996
V5009848
Try 5571
or
5569
Unfortunately neither worked, nor the numbers 2 apart or the one in the middle.
Thanks for trying though, I will contact the dealer tomorrow.
CDR-21 (210 in US?)
R1996
V5009848
Try 5571
or
5569
Just an update - I managed to obtain the correct radio code from http://instant-radio-code.co.uk/ for £8.99/$18 and displayed instantly on screen.
It might be useful if Loren's code doesn't work and/or your dealer is being awkward about it. They say 100% guareenteed to be the correct one at the time of manufacture, but of course I can only say that mine worked first time, don't know about anyone else.
6571 , sorry, I should have included it when I replied.
They require the model number and serial number. It's just a generic Becker form that you fill in, but a bit of Googling and I found the CDR-21 was a BE2280.
Edited by The Dangerman
I have the same problem with my Radio, I do not have the code to re-activate.
2001 Boxster S
Radio Becker 1
Type 4462
Serial No. X5012420
Ken
2001 Boxster S
Radio Becker 1
Type 4462
Serial No. X5012420
Ken
Try 0900
or
0998
Loren,
new car, no code.
CDR-220
4462
# 15006300
24/99
2002 Boxster
Thanks in advance
Try 8932
or
8930
Worked great! You are magic, really. I am curious as to how you do this, but I'm sure it's a trade secret. Thanks again.
CR-210 Radio Code
Model BE2182
Serial number 5004353
Can you please give me the radio code. It's in a '89 928 S4 track car, as a retrofit.
THANKS Loren,
Gary Knox
Sorry, I think I may have posted this improperly!! Bad newby <_<
Loren,
I think you may have answered this, but I can't find the response either here, in the Boxster site, nor the 928 site. Sorry, could you please give me the codes? THANKS
CR-210 Radio Code
Model BE2182
THANKS Loren,
Gary Knox
Loren,
CR-210 Radio Code
Model BE2182
THANKS Loren,
Gary Knox
Try 6904
or 6902
Loren,
CR-210 Radio Code
Model BE2182
THANKS Loren,
Gary Knox
Try 6904
or 6902
Loren: Neither of these two worked. Any others to put in? THANK YOU.
Loren,
CR-210 Radio Code
Model BE2182
THANKS Loren,
Gary Knox
Try 6904
or 6902
Please read the previous posts - if the numbers I gave you do not work then you need to contact your dealer or Becker. Last I heard - Becker charges $30.
I need to fix the horn but realized that I do not have the Radio code.
Here's the info.
Porsche CDR-220
Becker 1
Type: 4462
24/99
Serial: X5035639
CD: CDP2081
Thanks Loren!
Here's the info.
Porsche CDR-220
Becker 1
Type: 4462
24/99
Serial: X5035639
CD: CDP2081
Thanks Loren!
Try 0571
or
0569
