  • Replies 19.2k
  • Created
  • Last Reply
Top Posters In This Topic
Disconnected battery to replace MAF sensor and reset computer. Yes this worked and cleared my engine light for smog, and still driving without a check engine light. Thanks to all the board members that posted about the MAF's and helped me troubleshoot and correct my problem!
Now on to the radio code, like others here, I made sure I put my radio card in a secure place, maybe too secure, and can't remember where I put it.
2001 Boxster S
Radio: CDR-220
Type: 4462
Ser: X5016277
Thanks in advance Loren for the help!
Aaron
2001 Boxster S
Radio: CDR-220
Type: 4462
Ser: X5016277
Aaron
Try 9748
or
8746
If you have not already read this FAQ - please do so...
Lost Radio Code - FAQ, PLEASE READ THIS FIRST
Please help, I'm new to this site, and lost here on this forum! Is this the correct way to post a question?!?
Mine is a Porsche Boxster, CV, 2002, 5-speed, and I recently replaced the battery. I also need my code to the stereo, but had no luck getting it from the dealer, as I was told I need to bring my car in person. I live too far away and wonder if someone can help me get my stereo code?
CDR 220
Becker
Stereo serial number: 250 14597.
Is there any thing else I need to provide to enable me to find my code?
Thank you,
Cynthia
Edited by Cynthia
CDR 220
Becker
Thank you,
Cynthia
Try 9608 or 9606 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
CDR 220
Becker
Thank you,
Cynthia
Thank you for your quick reply, Loren. I tried the first stereo code you gave me: 9608, but I got the word to "WAIT". So then I turned the stereo off and on again, and turned the car ignition off and on multiple times, but I still have the stereo "WAIT" message showing. What do I do now?
DO you also need this info:
Becker 1 Serial # 250 14597, TYPE: 4462, 24/99 ?
Thank you for your time.
Cynthia
CDR 220
Becker
Thank you,
Cynthia
Cynthia
Did you read the FAQ? I think not...
Here we go
97 Boxster 5 spd
V5009402
R2896
CDR-210
Thanks in advance.
Try 9682
or
9680
Neither code worked. When my "CODE" shows up on the display I just need to input the #'s correctly then it should start working or do I have to press a button after the 4 digit code to "enter" it??
CDR 220
Becker
Thank you,
Cynthia
Cynthia
Yes, I did read the link, thank you...
Hello,
Could you please let me know the radio code for my car? It would be much appreciated!
2002 Boxster
Becker CDR-220
Serial#: 25015952
Type: 4462
Thanks in advance,
Rob P.
Here we go
97 Boxster 5 spd
V5009402
R2896
CDR-210
Thanks in advance.
Try 9682
or
9680
I tried 9682 and it worked. Had to enter code then press "up" on the tuner button. Thanks for your help.
Hello,
I'm about to replace the battery in my new 2001 996 Cab. I do not know the codeso... Following your directions I have the following info from my CDR-220 radio. Type 4462 Ser no. 15064782 24/99. Can you supply the code? Thanks
Hello from France
Boxster 2,7 Litres Year 2000
Becker CDR-220
Serial#: Y5025841
Type: 4467
Best regards
Edited by pierreB
