  • Replies 18.7k
  • Created
  • Last Reply
Top Posters In This Topic
Hi, I hope someone can help, I have a Base Cayenne 2004. I disconnect the battery and now I have lost the radio CODE. Any help would be appreciated.
CDR23 E1 EC:116
Model#: BE 6627
Serial#: 45019692
CDR23 E1 EC:116
Model#: BE 6627
Serial#: 45019692
Please read the FAQ - CDR-23 does not have a security code.
You said don't have code. Why radio read as Protect and I can do nothing?
From that FAQ that I asked you to read...
"CDR-23 (or later):
These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. Only a dealer or shop with a PST2 or PIWIS tester can replace a MOST bus radio (i.e. CDR-23, CDR-24)."
Is the original. The problem is that I add another radio JVC DVD to use the seat monitors. And I take off the original radio to use some cable to connect the two radios to same time. And when all connections was ready the Original radio Porsche CDR-23 read PROTECT and nothing happen if I press any radio button.
CDR-23 is on a fiber optic bus cable (MOST) if you disconnected the cables it won't work.
If you want/need to discuss this problem further please start a new thread - this thread is for Lost Radio Codes Only.
Loren,
You seem to be the go to person for radio codes. I have a 97 Boxster.
Radio 210
Model Number: R 2896
Serial Number: V5005478
Thanks for any help you can provide. I appreciate it.
Justin
Loren,
Radio 210
Justin
Try 1298
or
1296
If you have not already read this FAQ - please do so...
Lost Radio Code - FAQ, PLEASE READ THIS FIRST
Those codes didn't work, I tried all codes from 1200 - 1320. Thanks for trying, I really appreciate you getting back to me so quickly.
Loren,
I have just purchase a 2nd hand 98 Boxster.
You guessed it no radio code and the garage are not helping
Radio CR -11
Serial Number: V5006331
Chris
Loren, thank you for your patience and the information, the following is my radio information:
Becker 1
Type 4462
48/98
CDP 2081
Serial Number: X5025271
Thank for helping me retrieve the radio code for my vehicle. I hope I posted this the right way this time, so sorry.
V/r
Eric
Becker 1
Type 4462
48/98
CDP 2081
V/r
Eric
Try 8890
or
8889
Need help with the radio code on my newly purchased 2000 996:
CR-220
Type: 4362
24/99
Serial #: 15004912
Thanks in advance,
Mike
