the code did not work but by going up from 0820 code to 0832 it worked . you have saved my sound !!! THANKS!! THANKS!!
can you store code ? every time i turn off switch i have re enter code. thanks
  • Replies 18.7k
  • Created
  • Last Reply
Top Posters In This Topic
Hmm... sounds like someone rewired your radio.
All Porsche radios should be wired to unswitched power (which means they are always on).
Hello Loren,
I am hoping on receiving your help for code of the following unit:
CDR220
Type BE6625
Serial 25013769
Thank you !!
Klaus
Try 8655
or
8653
If you have not already read this FAQ - please do so...
Lost Radio Code - FAQ, PLEASE READ THIS FIRST
Hello Loren,
Unfortunately I have not yet been able to activate.
I have read your FAQ and I understand the odds of not being successful.
One point I noticed: Using the TP function the device type shows BE4462 (NOT 6625 as on outside label)
Would type 4462 yield a different code for Serial 25013769 ?
Thank you,
Klaus
No, the code is based on the serial number.
So if you gave me the correct serial number - then you have my best guess.
OK, I understand, Thank you for your help, I will keep trying some other combinations.
Klaus
FOLLOWUP: 8765 works
Code needed for CDR220
Type: BE 6625
Serial: 15006014
Thank you !
This is a different radio than the one you requested in Feb 2009?
Yes Sir. I have purchased 2 used radios, this one already in hand, another one coming soon (don't have serial yet).
These are purchased from EBAY, I can point to the auction if you would like.
They are for 2 buddies of mine.
Klaus
Try 1491
or
1489
FOLLOWUP: 1493 works
Getting ready to change the battery and can't find my code anywhere
Becker 1
4462
15075577
24/99
CDP2081
Thanx in advance
Stan
I had battery disconected on my 98 Boxster and lost radio code. Also I dont know how to enter code when I get it. Thanks, George
Becker CDR 210 Serial # 2282CU0W5020063
I need a lockout code for CDR-220, Serial #X5037388
Try 3030
or
3028
it didn't work. it went in lockout mode......
READ THE FAQ.
The codes 3030 and 3028 didn't work. It went in wait mode. Any sugestions??
Yes, as I have already told you. Read the FAQ - Read the FAQ - Read the FAQ
Thank you. I had a copy of the Becker software and came up with the same number based on my last 4 digits of seriall number. I am waiting to get back car from cam chain tensioners replacement and wanted to be ready to code the radio. I also searched the data base here and found out how to input #s. I have got a lot of good info here such as repairing convertable top drives etc. George
Try 0504
or
0502
CDR-220
2001 Boxster
Model Number 4462
Serial number y5060255
replaced battery, and faced with this dilemna.
Thank you folks for the help...
Robert
Hi , this is my first time to use the forum. I am going to require a radio code for my Boxster S it is a 2000 year. I will need to disconnect the battery for 5 min. to reset the DME after I change the MAF......The car never came with a code for the radio.
The radio is a Becker 1 CDR 220
Type 4462
Serial# Y5043547
Thankyou for all your help......Take care! Paul. :rolleyes:
Type 4462
Serial# Y5043547
Try 8894
or
8892
Try 3030
or
3028
READ THE FAQ.
Had to go through the Dealer. The code ended up being 3031. Thanks for your help Loren!!!!
