I have a 2014 Boxster S.  When I go to close my top, it gets stuck at the half way point.  After repeatedly pushing the open and close buttons...going back and forth, it will finally close.  It's getting more and more difficult for it to respond..  (I no longer open it in fear of it getting permanently stuck)
Can anyone tell me what may be causing this problem?  Do I need to replace the gears, etc...?  How do I recognize what is broken?
I cannot speak to the cause of your problem, but I have an ongoing problem with my '03's top refusal to go up due to the motor not getting power when the top-up button is pressed.  But the onset of this problem caused me to refer to the Owner's Manual which says how to disconnect the top's transmissions from the top and its framework, enabling one to raise it manually.  This is not easy to do in a raging thunderstorm, so I t's best to cast an eye skyward prior to depressing the top-down button.
