I've been chasing a rough idle for almost two months. 2011 Turbo, 120,000 miles.
There was a code for the 'valve lift controller.' Also got a check engine light. Oddly, it runs fine beyond idle besides a slight initial hesitation. Got another controller, but apparently there was a part change midway through production and it was incorrect. So we got the right one.
After installation, no change. The mechanic wasn't satisfied and got another. Same result.
Then someone on another forum mentioned first get Cayennes had a screen in the oil passage below the VLC which clogged.
Calling upon a previous similar issue in the LS of my Silverado where the screen in the oil pressure sensor gets clogged, I thought trying some Pennzoil might help. It works there so it may here as well.
(BTW, checked the parts diagram and even asked Gaudin Porsche parts folks--there is no screen in this engine. Perhaps a very small oil passage.)
The result is that while the engine is cold, the idle is still rough. When warmed, it is fine. Interestingly, shutting off the engine while rough usually smooths it on restart.
The engine light has gone out on its' own.
Ideas? I can't have the lucky sole example of this problem.
Engine light is back.
I cannot be the only one experiencing this!
Will look for new codes today.
Ideas?
