We put a PCM delete and a set of Recaro racing seats in this 997.1, still have factory seat belts, and were able to code out all the air bag modules (Thorax, Pretensioner for seat belt, AWS and Buckle) and for some reason we can't get the light to go off and following two codes to clear:
8045 Driver's Belt Tensioner, incorrect Coding
8046 Passenger's Belt Tensioner, incorrect Coding
I've played with PIWIS endlessly trying to recode the gateway module, everything I can think of to no avail.
Does anyone have any suggestions?
Too my knowledge you can not turn off safety features.
If the airbag is active or the light comes on then you likely still have an issue with that airbag.
