First off, I’m new to the 996 family. I purchased a 99' Cab a few weeks ago. It's a clean, higher mileage 6 speed (90k). I am enjoying it so far. While changing the oil I noticed the accelerator cable is a little frayed and loose.
From the OBD the TPS maxes at 70% with the pedal all the way down. I am guessing that is not right. I also note with it depressed all the way I can manually open the throttle about another 1/2”.
I have a few questions, am I correct, I am not getting max throttle in my current situation?
How hard is it to replace the cable and adjust? What gotchas should I be aware of?
Also, what is the correct, most succinct description of my 996 model?
Thanks in advance,
Chris
