CLU diagnostic help. Double beep when locking
Hi all thanks for the help. Vehicle 2003 Boxster non s. Has a double beep when locking the vehicle from the remote. You hear the locks lock than unlock than double beep. Faults 47 and 61 pop up. I have replaced both drivers and passengers side door lock assemblies with Porsche locks not aftermarket, also verified w/ build code M535. Faults clear out however return right away when attempting to lock. Looking at the actual values on the PIWIS, it does appear that all the door contacts and trunk switches are showing correct position when open or closed. One interesting observation, with the rear trunk in the open state all the locks function normally with just a singe beep when lock on the key is pressed or from the interior lock switch. Any thoughts are appreciated, thanks
Central locking synchronization
Fault code 46, 47
These faults are stored in the memory if at least one safe contact does not reach the safe position after two synchronisation actuations towards safe.
1. With PST 2 (drive links), check whether the servo motor reacts with the door closed. If the servo motors react, select "Driver's side locked" and "Passenger's
side locked" in the menu item Input signals, and close the doors
Vehicle not locked
Central locking limit position unlocked not reached
Fault code 61
This fault is stored in the following cases:
Short circuit to voltage/ground or open circuit in the supply lead to plug
II pin 3
I pin 5
I pin 28
Short circuit to voltage/ground or open circuit in plug I pin 29
Short circuit to voltage/ground or open circuit in plug I pin 30
