AIRBAG FAULT -  Chasing my tail!
2003MY 996 C4 Cab. Right hand drive (UK)
I still have a '85 Error ( Driver's Side Airbag Sensor failure).
I have now changed the crash sensor on the LH floor beam (Is there one on the RHS too?)
I've also changed the Driver's seatbelt receiver - Still the same code!
The last thing I guess is the airbag control module - Where is it located do we know? Any other ideas?
Any knowledge of Code 85 appreciated
The service manual says:
"Side-airbag sensor (sensor for airbag) Fault codes 85, 87"
"1. There is an open circuit in the wire to the sensor.
2. There is a short to ground / voltage between pin 3 (sensor for airbag) and control module pin 20 or pin 21
3. The sensor or control module is faulty. Check wire to the sensor for open circuit / leakage resistance. If no fault is detected in the wire, replace sensor"
