Hi
New to this old forum but was wondering if anyone has had to re-wire a headlight assembly as my turn signal will not work.
2002 Boxster S
Bulb is good and a new relay flasher and I have powered up the headlight assembly out of the car and everything works except the turn signal. The socket is good and I believe there is either a bad connection or a shorted wire inside the assembly. Has anyone run into this before?
Thanks for your input.
:welcomeani:
This usually caused by a bad (chassis) ground. Check both front and rear bulb sockets for resistance to ground (chassis). It should be zero or very very small.
